compile error after upgrade v.8.05
JKLee
Post by JKLee » Fri May 29, 2009 9:14 am
C++ Builder 2007
TeeChart v8.05
after update v8.04 -> v8.05 VCL, compile errors
Why? I have not modifyed any sources.
[BCC32 Error] Gdipapi.hpp(55): E2257 , expected
[BCC32 Error] Gdipapi.hpp(57): E2257 , expected
[BCC32 Error] Gdipapi.hpp(69): E2257 , expected
[BCC32 Error] Gdipapi.hpp(71): E2257 , expected
[BCC32 Error] Gdipapi.hpp(73): E2257 , expected
[BCC32 Error] Gdipapi.hpp(75): E2257 , expected
[BCC32 Error] Gdipapi.hpp(81): E2257 , expected
[BCC32 Error] Gdipapi.hpp(83): E2257 , expected
[BCC32 Error] Gdipapi.hpp(87): E2257 , expected
[BCC32 Error] Gdipapi.hpp(89): E2257 , expected
[BCC32 Error] Gdipapi.hpp(91): E2257 , expected
[BCC32 Error] Gdipapi.hpp(93): E2257 , expected
[BCC32 Error] Gdipapi.hpp(97): E2257 , expected
[BCC32 Error] Gdipapi.hpp(99): E2257 , expected
[BCC32 Error] Gdipapi.hpp(103): E2257 , expected
[BCC32 Error] Gdipapi.hpp(105): E2257 , expected
[BCC32 Error] Gdipapi.hpp(113): E2257 , expected
[BCC32 Error] Gdipapi.hpp(115): E2257 , expected
[BCC32 Error] Gdipapi.hpp(119): E2257 , expected
[BCC32 Error] Gdipapi.hpp(125): E2257 , expected
[BCC32 Error] Gdipapi.hpp(127): E2257 , expected
[BCC32 Error] Gdipapi.hpp(131): E2257 , expected
[BCC32 Error] Gdipapi.hpp(133): E2257 , expected
[BCC32 Error] Gdipapi.hpp(137): E2257 , expected
[BCC32 Error] Gdipapi.hpp(141): E2257 , expected
[BCC32 Error] Gdipapi.hpp(145): E2257 , expected
[BCC32 Error] Gdipapi.hpp(264): E2257 , expected
[BCC32 Error] Gdipapi.hpp(266): E2257 , expected
[BCC32 Error] Gdipapi.hpp(270): E2257 , expected
[BCC32 Error] Gdipapi.hpp(280): E2257 , expected
[BCC32 Error] Gdipapi.hpp(284): E2257 , expected
[BCC32 Error] Gdipapi.hpp(286): E2257 , expected
[BCC32 Error] Gdipapi.hpp(300): E2257 , expected
[BCC32 Error] Gdipapi.hpp(304): E2257 , expected
[BCC32 Error] Gdipapi.hpp(308): E2257 , expected
[BCC32 Error] Gdipapi.hpp(381): E2257 , expected
[BCC32 Error] Gdipapi.hpp(389): E2257 , expected
[BCC32 Error] Gdipapi.hpp(395): E2257 , expected
[BCC32 Error] Gdipapi.hpp(397): E2257 , expected
[BCC32 Error] Gdipapi.hpp(401): E2257 , expected
[BCC32 Error] Gdipapi.hpp(405): E2257 , expected
[BCC32 Error] Gdipapi.hpp(411): E2257 , expected
[BCC32 Error] Gdipapi.hpp(413): E2257 , expected
[BCC32 Error] Gdipapi.hpp(415): E2257 , expected
[BCC32 Error] Gdipapi.hpp(417): E2257 , expected
[BCC32 Error] Gdipobj.hpp(47): E2238 Multiple declaration for '_fastcall TGPRegion::TGPRegion(void *)'
[BCC32 Error] Gdipobj.hpp(39): E2344 Earlier declaration of '_fastcall TGPRegion::TGPRegion(void *)'
[BCC32 Error] Gdipobj.hpp(243): E2303 Type name expected
[BCC32 Error] Gdipobj.hpp(290): E2238 Multiple declaration for '_fastcall TGPBitmap::TGPBitmap(void *)'
[BCC32 Error] Gdipobj.hpp(269): E2344 Earlier declaration of '_fastcall TGPBitmap::TGPBitmap(void *)'
[BCC32 Error] Gdipobj.hpp(269): E2228 Too many error or warning messages
Post by Narcís » Fri May 29, 2009 11:33 am
Hi JKLee,
I have been able to reproduce the issue here adding line below to my unit.
#include <TeeGDIPlus.hpp>
I've added the defect to the bug list (TV52014200) and will try to fix it as soon as possible.
JKLee
Post by JKLee » Fri May 29, 2009 11:12 pm
Thank your reply.
as you say, I've included the header file. but same errors.
before not include TeeTools, It's Ok.
but my project Including TeeTools happend errors.
#include "TeeGDIPlus.hpp"
#include "Series.hpp"
#include "TeEngine.hpp"
#include "TeeProcs.hpp"
#include "TeeTools.hpp"
#include "Chart.hpp"
Post by Narcís » Wed Jun 10, 2009 10:14 am
Hi JKLee,
Yes, you are right. We have investigated the issue and the problem seems to be with usage of TeeGDIPlus unit in TeeTools.pas and C++ Builder. We have modified it to solve those problems. I'll send you an e-mail with modified TeeTools.pas.
davealaw
Re:
Post by davealaw » Thu Jun 11, 2009 3:51 pm
Narcís wrote:We have investigated the issue and the problem seems to be with usage of TeeGDIPlus unit in TeeTools.pas and C++ Builder. We have modified it to solve those problems. I'll send you an e-mail with modified TeeTools.pas.
I'm having exactly the same problem which has prevented me from using 8.05 and I have been waiting on a fix before I can continue on a project that uses it. Can you send me the updated file as well?
Dave
Re: compile error after upgrade v.8.05
Post by Narcís » Fri Jun 12, 2009 9:13 am
Hi Dave,
Sure, sent!
Yazou
Post by Yazou » Thu Jun 18, 2009 11:34 am
Me too i got compilation errors in gdipapi.hpp & gdipobj.hpp when i added Paging during the design time to my chart.
Can you send me the last *.hpp files please.
Post by Yeray » Thu Jun 18, 2009 12:03 pm
Hi Yazou,
We've sent you a mail with the file too.
vitbear
Post by vitbear » Thu Jun 25, 2009 11:57 am
I have the same problem with version 8.05
Please, send me fixed files too.
Vitali
Post by Narcís » Thu Jun 25, 2009 12:04 pm
Hi Vitali,
Just sent them.
gorry
Post by gorry » Thu Jun 25, 2009 12:15 pm
I too get the same compilation error after installing TeeChart Pro in C++Builder 2009. Please send the corrected hpp files.
Post by Narcís » Thu Jun 25, 2009 12:53 pm
Hi gorry,
I see your TeeChart Pro v8 VCL license is not a source code license so I'm not able to send you source code files with the fix. The solution will be included with next v8 maintenance release. In the meantime you can use v8.04.
msmorley
Post by msmorley » Sun Jun 28, 2009 11:40 am
Could you also send me the modified files, please. I've just reinstalled TeeChart (after a system upgrade) and the compilation breaks in the same fashion.
Kind Regards,
m.
Post by Narcís » Mon Jun 29, 2009 7:05 am
Hi msmorley,
Yes, I just sent you necessary file.
msmorley
Post by msmorley » Mon Jun 29, 2009 8:52 am
Narcís wrote:Yes, I just sent you necessary file.
Many thanks, that compiles fine now.
m.
