TpolarSeries and fillzone
Calou
Post by Calou » Wed Jun 03, 2009 8:55 am
I have a TpolarSeries and i am looking a way to fill each zone with a different color like the picture below
Is it possible?
Thanks for help
@Yeray: I've edited you post to make the picture visible
Post by Yeray » Wed Jun 03, 2009 11:33 am
Hi Calou,
Here is an example:
uses TeCanvas, Math;
var Colors: array of TColor;
var i: Integer;
  for i:=0 to 8 do
    if i > 0 then Series1.AddPolar(i*30, Series1.YValue[Series1.Count-1]);
    Series1.AddPolar(i*30, 0);
    if i < 8 then Series1.AddPolar(i*30, random*30);
  Series1.Pointer.Visible := false;
  SetLength(Colors,Series1.Count div 3);
  for i:=0 to length(Colors) do
    Colors[i] := RGB(Random(255), Random(255), Random(255));
var i: Integer;
    tmpPoints: TPointArray;
  SetLength(tmpPoints,3);
  for i:=0 to Series1.Count-1 div 3 do
     tmpPoints[0].X := Series1.CalcXPos(i*3);
     tmpPoints[0].Y := Series1.CalcYPos(i*3);
     tmpPoints[1].X := Series1.CalcXPos(i*3+1);
     tmpPoints[1].Y := Series1.CalcYPos(i*3+1);
     tmpPoints[2].X := Series1.CalcXPos(i*3+2);
     tmpPoints[2].Y := Series1.CalcYPos(i*3+2);
     Chart1.Canvas.Brush.Color := Colors[i];
     Chart1.Canvas.Polygon(tmpPoints);
PS: This may help when we'll implement the rose series (TV52013339)
Calou
Post by Calou » Wed Jun 03, 2009 1:06 pm
Exactly what i wanted to do
Thank you very much
Calou
Post by Calou » Thu Jun 04, 2009 1:08 pm
Could it be possible to have in the legend the signification of the color
For example a green square and text for signification, a red square and an other text...
In my case i want legend for the color not for series values
Post by Yeray » Thu Jun 04, 2009 2:34 pm
Hi Calou,
The possibility to have a fully customizable legend is already in the wish list (TV52010510). So I'm afraid that in the meanwhile the only solution you have is custom drawing to the canvas.
Calou
Post by Calou » Fri Jun 05, 2009 9:13 am
Ok for the legend
I have this code and i am surprised because the zone are not colored
procedure TfrmRoseVent.DrawAllPetales(num_chart:integer;prjt:string);
  prctg_max,prctg,ind: Integer;
  //parcours des enregs
  while not frmMain.IbcQryRd.Eof do
    //dessine le contour d'une pétale
    DrawPetale(num_chart,frmMain.IbcQryRd.FieldByName('ANGLE').AsInteger,frmMain.SpnEdtAngle.Value,prctg);
    ColorPetale(num_chart,ind,frmMain.IbcQryRd.FieldByName('VIT_MOY').AsFloat);
    frmMain.IbcQryRd.Next;
    Inc(ind,3);
  end;//fin du while parcours des enregs
//dessine une petale de la rose
procedure TfrmRoseVent.DrawPetale(num_chart,angle_deb, pas_angle: integer; prctg: double);
  //Déssine le contour
  TabSeriesRoseVent[num_chart].AddPolar(angle_deb,prctg);
  TabSeriesRoseVent[num_chart].AddPolar(angle_deb+pas_angle,prctg);
  TabSeriesRoseVent[num_chart].AddPolar(angle_deb+pas_angle,0);
//colorie toutes les pétales
procedure TfrmRoseVent.ColorPetale(num_chart,ind_serie:integer ;vit_moy:double);
  tmp_pts: TPointArray;
  SetLength(tmp_pts,3);
  //colorie
  tmp_pts[0].X:=TabSeriesRoseVent[num_chart].CalcXPos(ind_serie);
  tmp_pts[0].Y:=TabSeriesRoseVent[num_chart].CalcYPos(ind_serie);
  tmp_pts[1].X:=TabSeriesRoseVent[num_chart].CalcXPos(ind_serie+1);
  tmp_pts[1].Y:=TabSeriesRoseVent[num_chart].CalcYPos(ind_serie+1);
  tmp_pts[2].X:=TabSeriesRoseVent[num_chart].CalcXPos(ind_serie+2);
  tmp_pts[2].Y:=TabSeriesRoseVent[num_chart].CalcYPos(ind_serie+2);
  TabChrtRoseVent[num_chart].Canvas.Brush.Color := clYellow;
  TabChrtRoseVent[num_chart].Canvas.Polygon(tmp_pts);
What could be wrong?
Thanks for help
Post by Yeray » Fri Jun 05, 2009 9:41 am
Hi Calou,
Yes, the problem is that drawing directly to the canvas needs to be done into an event that is called every time the chart is painted. For example at OnAfterDraw event.
So, you should call your ColorPetale method at OnAfterDraw for example.
