Need a link between legend and chart series
JGM
Post by JGM » Tue Mar 07, 2006 1:31 pm
I have a number of series on my chart, but I don't display all the series in the chart's legend. I also have checkboxes enabled on the legend. Users can also add series to the chart - some of which will be displayed in the legend and some not.
I am trying to find a link between the items in the legend and their corresponding indices in the chart's series collection.
By way of illustration:
The following series exist on the chart:
Idx.
0 - Price
1 - Moving Average
3 - Bollinger band upper series
4 - Bollinger band lower series
5 - Moving Average #2
6 - MA #2's Bollinger upper series
7 - MA #2's Bollinger lower series
The following series are displayed in the legend:
Leg. Idx.
0 - Moving Average
1 - Bollinger upper series
2 - MA 2
3 - MA 2's Bollinger upper series
Each set of Bollinger bands (2 series) is represented by one legend item, so that the set can be activated/deactivated by one checkbox.
What I would ideally like to do in the ClickLegend handler is check whether the item clicked was a Bollinger band and if so, retrieve it's index in the chart's series collection so that whatever action is performed on the series will also be performed on it's 'partner' series, the Bollinger lower series which will always be at the next position.
I can retrieve the Legend index for the clicked item and I can also 'work with' it's corresponding series via tChart1.Chart.SeriesLegend(LegendIndex,false), but I can't retrieve the actual series index.
JGM
Post by Narcís » Tue Mar 07, 2006 2:22 pm
Hi JGM,
You can try using something like this:
			if (tChart1[tChart1.Series.IndexOf(tChart1.Chart.SeriesLegend(LegendIndex,false))] is Steema.TeeChart.Functions.Bollinger)
				//Your code here
Or just:
			if (tChart1.Chart.SeriesLegend(LegendIndex,false) is Steema.TeeChart.Functions.Bollinger)
				//Your code here
JGM
Post by JGM » Wed Mar 08, 2006 9:29 am
Thanks Narcís, that worked perfectly.
JGM
