Chris.CHWU
Post
by Chris.CHWU » Mon Dec 28, 2009 10:21 am
Hello:
We are using Build 3.5.3498.27376. We use the following code to adjust label angle of bottom axis.
Private Sub TChart_BeforeDrawSeries(ByVal sender As System.Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
Dim tchart As Steema.TeeChart.Chart = g.Chart
Dim iWidth As Integer = Math.Abs((tchart.Axes.Bottom.CalcXPosValue(1) - tchart.Axes.Bottom.CalcXPosValue(0))) / 4
// These codes are used to adjust box width, it works
For Each series As Steema.TeeChart.Styles.Series In tchart.Series
If TypeOf (series) Is Steema.TeeChart.Styles.Box Then
CType(series, Steema.TeeChart.Styles.Box).Box.HorizSize = iWidth
End If
Next
// We use this line to change label angle to 90, but the chart does not reflect to this change
tchart.Axes.Bottom.Labels.Angle = 90
End Sub
As you could see in the attached image, the box width is changed with the code, but the axis label angel is not changed.
- Box Plot Width and Angel.GIF (9.96 KiB) Viewed 6901 times
But we could see that the angel is changed to 90 in Chart Editor
- angel in editor is changed.GIF (18.92 KiB) Viewed 6901 times
Please advise how could we eliminate this issue, thanks
Post
by Sandra » Tue Dec 29, 2009 10:00 am
Hello Chris. CHWU
I think that your problem occurs because chart needs redraw or refresh. Please see next code and check works correctly.
Dim box1 As Steema.TeeChart.Styles.Box
Dim box2 As Steema.TeeChart.Styles.Box
Dim box3 As Steema.TeeChart.Styles.Box
Private Sub InitializeChart()
box1 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
box1.FillSampleValues()
box1.Position = 1
box2 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
box2.FillSampleValues()
box2.Position = 2
box3 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
box3.FillSampleValues()
box3.Position = 3
AddHandler tChart1.BeforeDrawSeries, AddressOf Me.tChart1_BeforeDrawSeries
tChart1.Draw()
End Sub
Private Sub tChart1_BeforeDrawSeries(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
Dim iWidth As Integer = (Math.Abs((tchart.Axes.Bottom.CalcXPosValue(1) - tchart.Axes.Bottom.CalcXPosValue(0))) / 4)
If (TypeOf series Is Steema.TeeChart.Styles.Box) Then
CType(series,Steema.TeeChart.Styles.Box).Box.HorizSize = iWidth
End If
Next
End Sub
I hope will helps.
