Hi All,
I am seeing a wired behaviour with CalcPosValue and RectTool.
I have attached the sample project so that you can run it 'as is' to reproduce the problem.
Once the form is loaded, just try to zoom before the rect tool starts.
Zoom very small area (2 pixel or something).
Now zoom again (same two pixel).
You would see the Recttool took the entire area.
This is wired.
See the screen shots below -
Avijit
Axis.CalcPosValue() bug or RectTool bug
- Screen Shots
- BUG.JPG (114.02 KiB) Viewed 7864 times
Re: Axis.CalcPosValue() bug or RectTool bug
Hello Avijit,
I have tried run your project and seems that doesn't work fine here. Please, you could attach again your project, because we can run it here.
Hello Sandra,
I have attached the project again.
Avijit
Avijit
Hello Avijit,
Ok, I could reproduce your problem and I have added your request in bug list with number [TF02015082]. We will try to fix it in next maintenances releases of TeeChart.Net.
