I have a graph with two options (line chart and area chart). The line chart is pretty fast even with lot of data.
But the area chart is very slow. I did some investigation with ants profiler to see which process is taking so much time.
I have attached a screenshot of the profiler results.
Is there any solution to this problem? It seems to occur in the teechart dll.
Area chart slow
Area chart slow
- profile result
- profile_result.jpg (296.58 KiB) Viewed 10123 times
Re: Area chart slow
Hello SPS,
Your arrow is pointing to System.Drawing.SafeNativeMethods+Gdip.GdipDrawLineI method and it is not a Steema method. This method is a .NET Framework method, and I fear, we can not do much for solve it. On the other hand, I recommend you try to using a HatchBrush (a brush with lines rather than a solid brush) and check if now, your application works faster than before.
Re: Area chart slow
Well it's still very slow with a hatchbrush.
When i run this simple sample project it takes like 15-20 sec to draw the graph:
Any other ideas would be appreciated.
Steema.TeeChart.Styles.Area area1 = new Steema.TeeChart.Styles.Area(this.teeChartControl.Chart);
area1.Brush.Solid = false; //DrawingBrush now returns: {System.Drawing.Drawing2D.HatchBrush}
teeChartControl.Series[0].FillSampleValues(100000);
Re: Area chart slow
Hello SPS,
I suggest two options:
1.- Take a look in the Tecnical Articles concretely in real time charting, where there are a example of optimize Chart to be faster.
2.- TeeChartDirect2D can greatly increase their responsiveness, as explain in this white papper.
I hope will helps.
I hope will helps.
Re: Area chart slow
Thanks for the suggestions, im looking into TeeChartDirect2D at moment. Is this only for .net 2.0 ? Because in .net 4.0 i get a slimDX version error.
Re: Area chart slow
Hello SPS,
I couldn't reproduce your problem using .net 4.0. S, please check if you have installed SlimDX correctly. If it is installed correctly, you can tell us exactly what say error message,
Re: Area chart slow
Installed the TeeChart for .NET digital signal processing, including the SlimDX Runtime Net20 (June 2010) installation (which installed correctly)
Then I opened the Direct2DDemo demo project. Run it and get the following message:
Could not load file or assembly 'SlimDX, Version=4.0.10.43, Culture=neutral, PublicKeyToken=b1b0c32fd1ffe4f9' or one of its dependencies. The system cannot find the file specified.
When i add SlimDx.dll as a reference to the project i get the following message:
Error 1 Assembly 'TeeChart.Direct2D, Version=4.1.2010.11172, Culture=neutral, PublicKeyToken=null' uses 'SlimDX, Version=4.0.10.43, Culture=neutral, PublicKeyToken=b1b0c32fd1ffe4f9' which has a higher version than referenced assembly 'SlimDX, Version=2.0.10.43, Culture=neutral, PublicKeyToken=b1b0c32fd1ffe4f9' c:\Program Files (x86)\Steema Software\TeeChart for .NET Digital Signal Processing\net40\TeeChart.Direct2D.dll Direct2DDemo2010
When i try it as a .net 2.0 project all goes fine. But i can't seem to find a working SlimDx.dll that works for .net 4.0?
Re: Area chart slow
Hello SPS,
Please, try to do as explain in this post, concretly section TeeChart Enviroment Setup, where you find next points:
- - Installation considerations
- Licensing issues
