The first label display incomplete in x axis.
I plot the graph using some points as the first attachment, including x1, y1, y2 axis. But when I remove some points in y1 axis, the graph changed as the second attachment, and first label in x1 axis displayed incomplete. Please help me to resolve it or give me a solution?
- The labels is complete
- label_appear.jpg (186.56 KiB) Viewed 12977 times
- The first label is incomplete
- label_disappear.jpg (152.97 KiB) Viewed 12967 times
Re: The first label display incomplete in x axis.
Hello sim,
I suggest you try to change your Minimum and Maximum Offset using something as next line of code:
Can you tell us if my suggestion help you to solve the problem?
Thank,
tChart1.Axes.Bottom.MinimumOffset = 20;
Thank,
Thanks, i resolved it as you said.
But I have a new question, when I remove the points in y1 axis, the y1 axis title is disappear as the attachment, I want that the y1 title display.
Please help me again, thanks.
- title_disappear.jpg (146.87 KiB) Viewed 12912 times
Hello sim,
If you disable the Left axis the title of axis disappears, so it depends if its axis is visible or not. I think you can do something as do in next code, where I have used the GetAxisLabels to add a empty string in the Left Axis labels:
Can you please, tell us if previous code works as you want?
InitializeChart();
Steema.TeeChart.Styles.Line Series1, Series2;
Series1 = new Line(tChart1.Chart);
Series2 = new Line(tChart1.Chart);
Series1.Add(1.0, 1.0);
Series1.Add(1.0e+3, 1.0e+1);
Series1.Add(1.0e+5, 1.0e+2);
Series1.Add(1.0e+6, 1.0e+3);
Series1.Add(1.0e+1, 1.0e+4);
Series1.Add(1.0e+8, 1.0e+5);
Series1.Add(1.0e+7, 1.0e+6);
Series2.Add(-1.0);
Series2.Add(-1.0e+1);
Series2.Add(-1.0e+2);
Series2.Add(-1.0e+3);
Series2.Add(-1.0e+4);
Series2.Add(-1.0e+5);
Series2.Add(-1.0e+6);
Series2.RefreshSeries();
Series2.VertAxis = VerticalAxis.Right;
Series1.VertAxis = VerticalAxis.Left;
tChart1.Axes.Left.Labels.Exponent = true;
tChart1.Axes.Right.Labels.Exponent = true;
//Axis Left
tChart1.Axes.Left.Labels.ValueFormat = "#.0 x10 E+0";
tChart1.Axes.Left.Ticks.Visible = false;
tChart1.Axes.Left.Title.Text = "Axis Y1";
//Axis Right
tChart1.Axes.Right.Labels.ValueFormat = "#.0 x10 E+0";
tChart1.Axes.Right.Title.Text = "Axis Y2";
tChart1.Axes.Bottom.Labels.Exponent = true;
//Axis Bottom
tChart1.Axes.Bottom.Labels.ValueFormat = "#.0 x10 E+0";
tChart1.Axes.Bottom.Title.Text = "Axis X1";
tChart1.GetAxisLabel += new GetAxisLabelEventHandler(tChart1_GetAxisLabel);
void tChart1_GetAxisLabel(object sender, GetAxisLabelEventArgs e)
if (sender == tChart1.Axes.Left)
e.LabelText = "";
Sorry, the question have not been resolved yet. Perhaps what i said is not clear.
I want that left axis title display, but the points on left axis is disappear. Please help me, thanks.
Hello sim,
I have understand you want that the values of axis aren't visible but title yes. So, I made a simple example where appears the title but not the values. Can you tell us which you don't like of my code, so we can try to find a good solution for you?
Hi Sandra,
I want the series disappear on left axis, not values. Please see the red line in the first attachment(left_appear).
After remove the series, the graph will changed as the second attachment(left_disappear), but I want the left axis title display.
Please again, thanks.
- Left_appear.jpg (171.36 KiB) Viewed 12881 times
- Left_disappear.jpg (198.31 KiB) Viewed 12871 times
Hello sim,
Ok. I have modified my previous project to third series disappears when the values of axes not appear. To do it I have used the property transparency of Series.
Can you tell if previous code help you to achieve as you want?
InitializeChart();
Steema.TeeChart.Styles.Line Series1, Series2, Series3;
//CheckBox
checkBox1.Checked = true;
// checkBox1.CheckedChanged += new EventHandler(checkBox1_CheckedChanged);
Series3 = new Line(tChart1.Chart);
Series2.Add(1.0e+3, 3.0e+1);
Series2.Add(1.0e+5, 1.0e+2);
Series2.Add(1.0e+6, 2.0e+3);
Series2.Add(1.0e+1, 1.0e+4);
Series2.Add(1.0e+8, 1.0e+5);
Series2.Add(1.0e+7, 3.0e+6);
Series3.Add(1.0);
Series3.Add(3.0e+1);
Series3.Add(-2.0e+2);
Series3.Add(3.0e+6);
Series3.Add(-2.0e+1);
Series3.Add(-3.0e+2);
Series1.VertAxis = VerticalAxis.Right;
Series3.VertAxis = VerticalAxis.Left;
//Axis Left
//Axis Right
//Axis Bottom
if (!checkBox1.Checked)
e.LabelText = "";
tChart1.ShowEditor();
private void checkBox1_CheckedChanged(object sender, EventArgs e)
if (Series3!= null)
if (checkBox1.Checked)
tChart1.Axes.Left.Ticks.Visible = true;
Series3.Transparency = 0;
Series3.ShowInLegend = true;
Series3.Transparency = 100;
Series3.ShowInLegend = false;
Hi sandra,
Sorry, the issue had not been resolved yet. I can not do it as you said. Because the points which combined the series3 is on the graph yet as you said, I want only series1 and series2 on there.
And I think the issus is not easy to solve.
Hello sim,
Ok. I suggest other solution, where I have drawn the title of vertical axes directly in the canvas.
Can you tell us if previous code works as you expect?
InitializeChart();
Steema.TeeChart.Tools.Annotation ann;
//CheckBox
Series3.Add(1.0);
//Axis Left
//Axis Right
//Axis Bottom
tChart1.AfterDraw += new PaintChartEventHandler(tChart1_AfterDraw);
tChart1.Draw();
void tChart1_AfterDraw(object sender, Graphics3D g)
string sleft = "Axis Y1";
string sright = "Axis Y2";
string sbottom = "Axis X1";
//Title Axis Left
g.TextAlign = StringAlignment.Far;
g.RotateLabel(rect.Left-(tChart1.Axes.Left.MaxLabelsWidth()+20), (rect.Height+ sleft.Length) / 2 ,sleft,90);
//Title Axis Right
g.TextAlign = StringAlignment.Near;
g.RotateLabel( rect.Right+(tChart1.Axes.Right.MaxLabelsWidth()+20), (rect.Height+sright.Length) / 2 , sright, -90);
//Title Axis Bottom
if (Series3 != null)
tChart1.Axes.Left.Visible = true;
Series3.Active = true;
tChart1.Axes.Left.Visible = false;
Series3.Active = false;
Hi sandra,
Ok, thank you very much, I achieve as you said.
Hello sim,
I am glad that your problem are solved
