How to refesh chart once 'chart area' is draged?
Neelam
Post by Neelam » Mon May 28, 2012 10:20 am
How to refresh chart once 'chart area' is draged?
I am plotting a report chart based on some filteration,chart is plotting correctly but when i dragged on chart area toward right side my chart cruves(Line series) and axes data (y primary and y secondary) is changed(which is fine) but when i change my filteration its seems my chart is not refeshing properlly.(may be its saving somewhere in cache the previous draged status...not know).
I am using TeeChart.Silverlight(4.1.2012.1033)
I have tried with - 1:tChart.AutoRepaint = false;,tChart.AutoRepaint = true;
2 tChart.Invalidate() 3: TeeChart.DataContext = null;
but its not wroked for me.
Satyendra
Re: How to refesh chart once 'chart area' is draged?
Post by Sandra » Mon May 28, 2012 2:37 pm
Hello Neelam,
As I told you in this thread you can use to redraw the chart, the property of MainPage Visibiblity and set it to Visible as do in next lines of code:
 //Add it to redraw
            this.Visibility = System.Windows.Visibility.Visible;
So, I think you can use this property every time you need to redraw the chart. Can you confirm us if it solve your problem?
I hope will helps.
Neelam
Post by Neelam » Tue May 29, 2012 6:24 am
Thanks for yr reply.
Its seems you have not understand the actual issue.i am attaching a file pls refer for more brief on issue.
I dont want to redraw the chart.
Satyendra
ChartDraggedIssue.rar
Chart dragged issue brief
(224.26 KiB) Downloaded 1758 times
Post by Sandra » Wed May 30, 2012 10:08 am
Hello Neelam,
Thanks for extra information. I have made a simple code where I am initializing the chart every time I am changing the scenario and I think you can use to achieve as you want.
 Steema.TeeChart.Silverlight.Styles.Line Series1, Series2;
        public MainPage()
            //Series
            //comboBox
            this.comboBox1.Items.Add("Scenario A");
            this.comboBox1.Items.Add("Scenario B");
            this.comboBox1.SelectedIndex = 0;
            this.comboBox1.SelectedItem = 0;
            comboBox1.SelectionChanged +=new SelectionChangedEventHandler(comboBox1_SelectionChanged);
           // comboBox1
            InitializeChart();
            Scrolling();
        void comboBox1_SelectionChanged(object sender, SelectionChangedEventArgs e)
            switch(comboBox1.SelectedIndex)
                case 0:
                    tChart1.Clear();
                    InitializeChart();
                    Scrolling();
                    break;
                case 1:
                    tChart1.Clear();
                    Series1 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
                    Series1.FillSampleValues();
                    Scrolling();
                    break;
            Series2 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
            Series1.Add(0, 0.05);
            Series1.Add(1, 0.1);
            Series1.Add(2, 0.15);
            Series1.Add(3, 0.2);
            Series1.Add(4, 0.25);
            Series1.Add(5, 0.30);
            Series1.VertAxis = VerticalAxis.Left;
            Series2.Add(0, 35);
            Series2.Add(1, 20);
            Series2.Add(2, 150);
            Series2.Add(3, 98);
            Series2.Add(4, 75);
            Series2.Add(5, 120);
            Series1.VertAxis = Steema.TeeChart.Silverlight.Styles.VerticalAxis.Left;
            tChart1.Axes.Right.Visible = true;
            Series2.VertAxis = Steema.TeeChart.Silverlight.Styles.VerticalAxis.Right;
        private void Scrolling()
            tChart1.Zoom.Allow = false;
            tChart1.Panning.Allow = Steema.TeeChart.Silverlight.ScrollModes.Horizontal;
            tChart1.Panning.MouseButton = System.Windows.Browser.MouseButtons.Left;
Can you tell if it works as you expect?
I hope will helps.
