I'm using GalleryPanel to show several predefined charts with different series types.
Is it possible to select (in runtime) a specific chart type based on a saved parameter? I display GalleryPanel window several times and I want to keep last selection active.
Setting SelectedChart to a specific value doesn't seem to work. Though SelectedChart property is set correctly but I can't see it in the window (the border of the specific chart is not highlighted).
Sample code in vb.net looks like this:
For Each galleryChart As GalleryChart In _galleryPanel.Charts
If galleryChart(0).GetType() Is expectedTeeChartType Then
_galleryPanel.SelectedChart = galleryChart
Exit For
End If
Next
regards, Adam
GalleryPanel - activate specific chart
Re: GalleryPanel - activate specific chart
Hello Adam,
I have made a simple code using a GalleryChart and it works in correct way for me:
Could you tell us if it help you to solve your problem? If it doesn't help you, please send us a simple code because we can try to reproduce your problem.
I hope will helps.
Private lineSeries1 As Steema.TeeChart.Styles.Line
Private galleryPanel1 As GalleryPanel
Public Sub New()
' This call is required by the designer.
InitializeComponent()
InitializeChart()
End Sub
Private Sub InitializeChart()
lineSeries1 = New Steema.TeeChart.Styles.Line(TChart1.Chart)
lineSeries1.FillSampleValues(10)
galleryPanel1 = New GalleryPanel()
Me.Controls.Add(galleryPanel1)
galleryPanel1.Left = TChart1.Left - 200
galleryPanel1.Top = TChart1.Top
galleryPanel1.Width = 200
galleryPanel1.Height = TChart1.Height
galleryPanel1.NumRows = 3
galleryPanel1.NumCols = 2
galleryPanel1.CreateGallerySeries(GetType(Steema.TeeChart.Styles.Line))
galleryPanel1.CreateGallerySeries(GetType(Steema.TeeChart.Styles.Bar))
galleryPanel1.CreateGallerySeries(GetType(Steema.TeeChart.Styles.Points))
galleryPanel1.CreateGallerySeries(GetType(Steema.TeeChart.Styles.Area))
AddHandler galleryPanel1.OnChangeChart, AddressOf galleryPanel1_OnChangeChart
AddHandler galleryPanel1.OnSubSelected, AddressOf galleryPanel1_OnSubSelected
End Sub
Private Sub galleryPanel1_OnChangeChart(sender As Object, e As System.EventArgs)
Dim s As Steema.TeeChart.Styles.Series = TChart1(0)
Steema.TeeChart.Styles.Series.ChangeType(s, galleryPanel1.SelectedChart(0).[GetType]())
End Sub
Private Sub galleryPanel1_OnSubSelected(sender As Object, e As System.EventArgs)
galleryPanel1.SetSubSelected(TChart1(0), CInt(galleryPanel1.SelectedChart.Tag))
End Sub
I hope will helps.
Hello Sandra.
No doubt that your code works, I found the same sample in Feature demo.
But this is not what I was asking for. This code does not show how to select specific chart type in gallery panel.
Your code changes series type of a sample chart that is shown next to gallery panel when one of the chart type in gallery panel is clicked.
My question was how to programatically select on of the chart types on the gallery panel itself (without any sample chart shown).
I want to show a gallery panel but with 'Bar' styles chart already selected, then in your code it would be something like this:
galleryPanel1.SelectedChart = galleryPanel.Charts(1) <---- this assignment does not work. Well, the property is set correctly, but I can't see it on the screen. Bar series chart is not selected (highlighted).
I attached two sample screenshots.
selected.png - this is how I would like gallery panel to look like
notselected.png - this is how it looks now though I set galleryPanel1.SelectedChart property to a correct value.
regards, Adam
regards, Adam
- notselected.png (18.47 KiB) Viewed 9669 times
- selected.png (21.03 KiB) Viewed 9668 times
Hello Adam,
Sorry for the delay. The property you are using to set the Chart(galleryPanel1.Charts(1)) is correct, but you must change the style of subChart as I make in next c# code:
Could you tell us if previous code works as you want?
I hope will helps.
tChart1.Series.Add(lineSeries1 = new Steema.TeeChart.Styles.Line());
lineSeries1.FillSampleValues(10);
galleryPanel1 = new GalleryPanel();
this.Controls.Add(galleryPanel1);
galleryPanel1.Left = tChart1.Left - 200;
galleryPanel1.Top = tChart1.Top;
galleryPanel1.Width = 200;
galleryPanel1.Height = tChart1.Height;
galleryPanel1.NumRows = 3;
galleryPanel1.NumCols = 2;
galleryPanel1.CreateGallerySeries(typeof(Steema.TeeChart.Styles.Line));
galleryPanel1.CreateGallerySeries(typeof(Steema.TeeChart.Styles.Bar));
galleryPanel1.CreateGallerySeries(typeof(Steema.TeeChart.Styles.Points));
galleryPanel1.CreateGallerySeries(typeof(Steema.TeeChart.Styles.Area));
galleryPanel1.OnChangeChart += new EventHandler(galleryPanel1_OnChangeChart);
galleryPanel1.OnSubSelected += new EventHandler(galleryPanel1_OnSubSelected);
SetDefaultSelect();
tChart1.Draw();
private void SetDefaultSelect()
galleryPanel1.SelectedChart = galleryPanel1.Charts[0];
galleryPanel1.SelectedChart.Aspect.View3D = true;
galleryPanel1.SelectedChart.Panel.Gradient.Visible = true;
galleryPanel1.SelectedChart.Panel.Gradient.Direction = LinearGradientMode.Vertical;
galleryPanel1.SelectedChart.Panel.Gradient.StartColor = Color.Silver;
galleryPanel1.SelectedChart.Aspect.Rotation = 345;
galleryPanel1.SelectedChart.Header.Font.Bold = true;
galleryPanel1.SelectedChart.Header.Font.Color = Color.Black;
galleryPanel1.SelectedChart.Header.Font.Size = 9;
galleryPanel1.SelectedChart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.Raised;
private void galleryPanel1_OnChangeChart(object sender, System.EventArgs e)
Steema.TeeChart.Styles.Series s = tChart1[0];
Steema.TeeChart.Styles.Series.ChangeType(ref s, galleryPanel1.SelectedChart[0].GetType());
private void galleryPanel1_OnSubSelected(object sender, System.EventArgs e)
galleryPanel1.SetSubSelected(tChart1[0], (int)galleryPanel1.SelectedChart.Tag);
I hope will helps.
Thanks Sandra, now it works.
But, IMHO, SelectedChart property setter should do this code "for us", so we don't have to know all these visual panels, gradients, levels changes. But it's just my suggestion.
Thanks again,
Adam
Thanks again,
Adam
Hello Adam,
I am glad my suggestion code works in your end
On the other hand, I have added your request in wish-list with number [TF02016520] we will try to consider its inclusion to upcoming versions of TeeChartFor.Net.
Hello Sandra.
One more question with gallery panel.
You told me how to select (highlight) specific chart in gallery panel.
But I also want to change sub-type of the chart (in run-time).
I can see that chart sub-type is passed via SelectedChart.Tag property and it's used in OnSubSelected.
So I want to select (highlight) specific chart type and also sub-type (passed to procedure as a integer parameter). How can I do this?
regards, Adam
regards, Adam
I already found a solution.
I just had to change SelectedChart series based on saved tag parameter.
Adam
Adam
