Smooth lines
Anthony
Smooth lines
Post by Anthony » Thu Jan 13, 2005 11:36 am
Is there an option in TeeChart fro drawing smooth lines for data series ?
In my application all series points are connected with straight lines.
(I remember splines are doing a great job for drawing smooth lines)
In the TeeChart documentation I went thru all the different line options (fastline, bezier) but I did not come across something about smooth lines.
Some help would be nice.
Antoon Koster
Netherlands
Post by Narcís » Thu Jan 13, 2005 12:39 pm
Hi Antoon,
You can use the smoothing function, creating a line series and setting it's datasource to a smoothing function with another line series as source. Then you can hide the source line series if you wish.
Anthony
Post by Anthony » Fri Jan 14, 2005 8:32 am
Thanks for your reply. I studied the TeeChart examples, and tried the following, but no smooth lines ....
Any idea what might be wrong ...
My code looks like:
internal void SetLocationSeries()
Steema.TeeChart.Styles.Line line;
int iSeries=0;
for (int iPar=0;iPar<noPars;iPar++)
for (int iTime=0;iTime<noTimes;iTime++)
float[] xValues = new float[noLocs];
float[] yValues = new float[noLocs];
line = new Steema.TeeChart.Styles.Line();
line.CustomVertAxis = customAxis[iPar];
// populating series
line.XValues.DateTime = false;
// line.Marks.Visible = true;
line.Pointer.Visible = true;
line.Pointer.Style = pointerStyles[iPar];
line.Color = lineColors[iSeries];
line.LinePen.Width = 1;
// Smooth lines
smoothLine = new Steema.TeeChart.Styles.Line();
Steema.TeeChart.Functions.Smoothing
smoothing = new Steema.TeeChart.Functions.Smoothing();
smoothing.Interpolate = true;
smoothing.Period = 1;
smoothing.Factor = 10;
smoothLine.Function = smoothing;
smoothLine.DataSource = line;
smoothLine.Visible = true;
tChart1.Series.Add(smoothLine); // add smooth line
for (int iLoc=0;iLoc<noLocs;iLoc++)
smoothLine.Labels.Add(gsLocations[iLoc]);
xValues[iLoc] = iLoc;
yValues[iLoc] = gsSeries[iPar,iLoc,iTime];
tChart1.Series[iSeries].Add(xValues,yValues);
tChart1.Series[iSeries].Title =
gsParameters[iPar] + this.dateTimes[iTime];
tChart1.BackColor = Color.White;
iSeries++;
noSeries = iSeries;
I am using 8 data points per series. That's enough for proper smooting I guess.
Best regards,
Antoon Koster
Post by Narcís » Fri Jan 14, 2005 9:47 am
Hi Antoon,
You should use
smoothLine.CheckDataSource();
when populating your input series manually.
Anthony
Post by Anthony » Fri Jan 14, 2005 12:39 pm
Hi Narcis,
I must say I already tried your suggestion, as I found that extra line of code
in the TeeChart example for smoothing lines.
But this did not have any effect for me ... still straight lines
Any idea what may be wrong ??
Antoon Koster
[/img]
Post by Pep » Wed Jan 26, 2005 5:17 pm
Hi Antoon,
have you seen the example of this Function type in the Demo Features project (included with the TeeChart for Net v1 installation ) under :
What's New -> Welcome ! -> New Functions -> Smoothing SpLine ?
It shows how to do this.
Anthony
Post by Anthony » Thu Jan 27, 2005 11:31 am
Yes, I walked thru that example many times, and copied some code from it, but I don't get the smooth spline even after 2 days working ....
I must say, I (and my boss) will be VERY PLEASED if you could send me a complete Visual Studio .NET solution (so a *.sln file) with all the files included for that demo, so that I can check if I get the smooth spline.
Maybe there is something wrong with the installation, In that case I can check that.
My email is: antoon.koster@wldelft.nl
Kind regards,
Antoon Koster
Netherlands
Post by Pep » Fri Jan 28, 2005 3:32 pm
Hi Antoon,
te sources of the Demo Features project are included in the TeeChart for Net installation, you can find them under :
F:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject
