ColorBand bug
neurosoft
ColorBand bug
Post by neurosoft » Tue Oct 08, 2013 8:35 am
Hello!
If I add ColorBand to TChart, then remove it, some dirt stays on the screen.
With ColorBand
After ColorBand removing
Here is application sample
TChartTest.zip
(9.98 KiB) Downloaded 1614 times
Re: ColorBand bug
Post by Sandra » Tue Oct 08, 2013 12:17 pm
Hello neurosoft,
I can reproduce your problem. I have added it in bug list report with number [TW16016733]. We will try to fix it to upcoming versions of TeeChartFor.Net. On the other hand, at the moment, you can use next workaround to solve your problem:
        //TChart MyTChart;
        public MainWindow()
            MyTChart.Aspect.View3D = false;
            MyTChart.Width = 400;
            MyTChart.Height = 300;
            MyTChart.Axes.Left.SetMinMax(0, 10);
            colorBand = new ColorBand();
            MyTChart.Tools.Add(colorBand);
            colorBand.Axis = MyTChart.Axes.Left;
            colorBand.Color = Colors.Green;
            colorBand.End = 7;
            colorBand.ResizeEnd = true;
            colorBand.ResizeStart = true;
            colorBand.Start = 3;
        ColorBand colorBand;
        private void Button_Click(object sender, RoutedEventArgs e)
          colorBand.EndLine.Active = false;
          colorBand.StartLine.Active = false;
          MyTChart.Tools.Remove(colorBand);
Could you confirm us if previous code works in your end?
neurosoft
Re: ColorBand bug
Post by neurosoft » Tue Oct 08, 2013 12:27 pm
Thank you, workaround works for me.
But I'll also wait for updated version.
neurosoft
Re: ColorBand bug
Post by neurosoft » Mon Nov 11, 2013 1:58 pm
Hello!
I've just tried TeeChartNET2013_4.1.2013.11080, but this bug [TW16016733] is not fixed.
Please explain when it will be removed?
Re: ColorBand bug
Post by Sandra » Mon Nov 11, 2013 4:34 pm
Hello neurosoft,
The bug isn't still fixed. We will try to fix it to upcoming versions of TeeChartFor.Net asap. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
neurosoft
Re: ColorBand bug
Post by neurosoft » Wed Dec 11, 2019 6:07 am
Hello!
Just for now this bug is not fixed (Six years!). How long to wait?
Now we use version for WPF 4.2019.5.15
Neurosoft company
Re: ColorBand bug
Post by Christopher » Thu Dec 12, 2019 9:24 am
okay, we've finally managed to fix this issue which you can see on our issue-tracker as id=340. We wish to apologize for the delay in the fix, and the fix will become available in the next build of TeeChart which is due before the end of this year.
