LinearGage numeric value
Thomas
Post by Thomas » Sat Jan 18, 2014 4:33 pm
Hi! I'm using Xamarin.Android teechart.
I want to place numeric representation of value in LinearGauge in center of bar (like on screenshot)
I draw that value in AfterDraw event.
But when i calculate size from the top left corner of chart - and adjust it to specific device - on another device it is in wrong place (i use proper px to dp transformation). I need calculate text position from border top left corner (not whole chart corner)
1) how to get border top left corner coordinates (red arrow on screenshot)? i can't find appropriate properties.
2) how to change border color?
Thanks in advance
Re: LinearGage numeric value
Post by Narcís » Mon Jan 20, 2014 3:02 pm
Hi Thomas,
1. You can do this:
  public class MyLinearGauge : LinearGauge
    public MyLinearGauge(Chart chart) : base(chart) { }
    public Rectangle AxisRectangle
      get
        int height, width, x, y;
        if (Horizontal)
          height = Ticks.VertSize;
          width = Utils.Round(INewRectangle.Width * 0.8);
          x = (INewRectangle.X + (INewRectangle.Width / 2)) - (width / 2);
          y = INewRectangle.Y + ((INewRectangle.Height - height) / 2);
          height = Utils.Round(INewRectangle.Height * 0.8);
          width = Ticks.VertSize;
        return new Rectangle(x, y, width, height);
  [Activity(Label = "TeeChart for MonoDroid Demo", MainLauncher = true)]
  public class Activity1 : Activity
    protected override void OnCreate(Bundle bundle)
      base.OnCreate(bundle);
      InitializeChart();
    private Steema.TeeChart.TChart tChart1;
    MyLinearGauge gauge;
      tChart1 = new Steema.TeeChart.TChart(this);
      gauge = new MyLinearGauge(tChart1.Chart);
      gauge.FillSampleValues();
      tChart1.AfterDraw += tChart1_AfterDraw;
      gauge.Frame.InnerBand.Color = Color.Cyan;
      SetContentView(tChart1);
      Point topleft = gauge.AxisRectangle.Location;
      g.Pen.Width = 3;
      g.Pen.Color = Color.Pink;
      g.Line(topleft, new Point(200, 10));
2. See gauge.Frame.InnerBand.Color property in the example.
Thomas
Post by Thomas » Tue Jan 21, 2014 1:14 pm
Thanks. 1-st part works perfect.
Frame color deosn't work. When i make FrameVisible, disable Middle and outer bands It draws one more rectangle outside small thin frame. Seems like frame on first screenshot - is not related to LinearLayout.Frame property.
Post by Narcís » Tue Jan 21, 2014 2:21 pm
Hi Thomas,
Thomas wrote: Frame color deosn't work. When i make FrameVisible, disable Middle and outer bands It draws one more rectangle outside small thin frame. Seems like frame on first screenshot - is not related to LinearLayout.Frame property.
I'm not sure about which is the problem you describe. Adding this code:
      gauge.Frame.Visible = true;
      gauge.Frame.MiddleBand.Visible = false;
      gauge.Frame.OuterBand.Visible = false;
I get a chart like in the image below. Is that what you get? What's the problem with it?
Thomas
Post by Thomas » Wed Jan 22, 2014 9:24 am
I have another problem. When i draw line from Point
from your first response everything is OK on all devices. The line draws from corner.
But when I try to draw text with
g.TextOut (topleft.X, topleft.Y, "1234");
text is drawed on different positions on Y axis on different devices. g.TextOut works with the same coordinate system? How to draw text in center of bar?
Post by Narcís » Wed Jan 22, 2014 10:26 am
Hi Thomas,
Thomas wrote:g.TextOut works with the same coordinate system?
Yes.
Thomas wrote:How to draw text in center of bar?
Continuing with the MyLinearGauge example, you can do this:
      g.Pen.Width = 3;
      Point center = new Point(topleft.X + gauge.AxisRectangle.Width / 2, topleft.Y + gauge.AxisRectangle.Height / 2);
      g.Font.Color = Color.Red;
      g.TextOut(center.X, center.Y, "My custom text");
With a Bar series, this:
      InitializeChart();
    Bar bar1;
    Rectangle[] barRect;
      bar1 = new Bar(tChart1.Chart);
      bar1.FillSampleValues();
      barRect = new Rectangle[bar1.Count];
      bar1.GetBarStyle += bar1_GetBarStyle;
    void bar1_GetBarStyle(CustomBar sender, CustomBar.GetBarStyleEventArgs e)
      barRect[e.ValueIndex] = sender.BarBounds;
      for (int i = 0; i < bar1.Count; i++)
        string text = bar1.YValues[i].ToString();
        SizeF textSize = g.MeasureString(g.Font, text);
        int X = barRect[i].X + Steema.TeeChart.Utils.Round(barRect[i].Width / 2) - Steema.TeeChart.Utils.Round(textSize.Width / 2);
        int Y = barRect[i].Y + Steema.TeeChart.Utils.Round(barRect[i].Height / 2) - Steema.TeeChart.Utils.Round(textSize.Height / 2);
        g.TextOut(X, Y, text);
Thomas
Post by Thomas » Thu Jan 23, 2014 10:05 am
Size of drawing text is strange. Text "100000" has height > widht. height is very big. I
I found solution
var topleft = gauge.AxisRectangle.Location;
			g.TextOut (topleft.X +  gauge.AxisRectangle.Width/2, topleft.Y - (int)textSize.Height + gauge.AxisRectangle.Height - (gauge.AxisRectangle.Height - g.Font.Size) / 2 + 2, value);
It works.
I have last question. On some devices CircularGauge axis labels are far from the border(see screenshot), on other near the border(frame). All ticks sizes are zero. How to set labels near the frame?
Post by Narcís » Thu Jan 23, 2014 11:56 am
Hi Thomas,
Thomas wrote:Size of drawing text is strange. Text "100000" has height > widht. height is very big.
Those are decimals, that's because width and height are float numbers. You can check it using this code:
      g.Font.Size = 14;
      g.Font.Bold = true;
      string text = "100000";
      int x = Steema.TeeChart.Utils.Round(textSize.Width);
      int y = Steema.TeeChart.Utils.Round(textSize.Height);
      g.TextOut(x, y, text + ". Position: " + x.ToString() + " - " + y.ToString());
Thomas wrote:On some devices CircularGauge axis labels are far from the border(see screenshot), on other near the border(frame). All ticks sizes are zero. How to set labels near the frame?
Which kind of devices? Are those low resolution screened devices? Which sort of screens in the table here? Anyway, you can change that with Ticks.VertSize:
      circularGauge1.Ticks.VertSize = 0;
Thomas
Post by Thomas » Fri Feb 14, 2014 12:31 pm
Still cannot change border color (see my 1st post in this topic).
Frame property is other frame, not the frame near hand (see attachment to first post).
Post by Narcís » Fri Feb 14, 2014 4:19 pm
Hi Thomas,
Apologies for the misunderstanding. That frame is the axis, hence you can change its pen properties like this:
      gauge.Axis.AxisPen.Color = Color.Red;
      gauge.Axis.AxisPen.Width = 5;
Is that what you were looking for?
Thomas
Post by Thomas » Sun Feb 16, 2014 11:22 am
Thanks. It works
