When I add a scroll pager the original chart and the scrollpager seems to have the same width, but when I maximize the windows I see they not fit in the right side
You can reproduce in this example pressin button1 and then maximazing the window
http://193.145.251.126/pnp/files/xMAsSQ ... Scroll.zip
Scrollpager margins
Scrollpager margins
- scrollpager.png (10.34 KiB) Viewed 5205 times
- Guru
Re: Scrollpager margins
Okay, I have been able to reproduce this problem and have added it as ticket id=589. As you can see, this ticket has already been marked as fixed, and this fix will be available in the next maintenance release, due out very shortly.wakeup wrote:You can reproduce in this example pressin button1 and then maximazing the window
