webchart zoom error, Line transparency 3d errors, etc.
Re: webchart zoom error, Line transparency 3d errors, etc.
Post by Narcís » Thu Feb 13, 2014 2:04 pm
Hi ikke,
You should install the Visual Studio 2008 components to get the .NET Framework 3.5 assemblies. VS2008 was released alongside .NET Framework 3.5.
ikke
Post by ikke » Wed Feb 19, 2014 12:23 pm
I try to do it !
See the Picture ....
Reinstall will not work ...
ikke
Post by ikke » Wed Feb 19, 2014 12:29 pm
in reinstalling
Post by Christopher » Thu Feb 20, 2014 8:26 am
ikke wrote:...
in reinstalling
We are sorry you have received this error. Can you please tell me on which Operating System you were running the installer on and which version of Visual Studio you chose for installation?
ikke
Post by ikke » Thu Feb 20, 2014 11:47 am
We use ...
Windows 8
VS2012
Framework 3.5
Framework 4.5
Post by Christopher » Thu Feb 20, 2014 11:50 am
ikke wrote:We use ...
Windows 8
VS2012
Framework 3.5
Framework 4.5
Can I please ask you to tell me what happens if you run the installer again, but this time changing the name of the installation folder slightly so the installer has to create a new one? Do you still get the same error?
ikke
Post by ikke » Thu Feb 20, 2014 12:45 pm
Now i delete the Folder ... and now i can install the
Version VS2012 with Framework 4.5
But how i can install
Version VS2012 with Framework 3.5
We need both Framework 3.5 and 4.5 for VS2012 !
Post by Christopher » Thu Feb 20, 2014 1:42 pm
ikke wrote:Now i delete the Folder ... and now i can install the
Unfortunately, this is a limitation with the present installer which will be resolved for the next maintenance release.
To obtain the net35 assemblies, please re-run the installer *selecting a unique folder name* and choose the VS2008 option.
ikke
Post by ikke » Thu Feb 20, 2014 2:38 pm
I tried to do this, but an Hreg tool has Errors.
And the ChartEditor is not found in Registry ....
It don't works ...
Post by Christopher » Thu Feb 20, 2014 2:42 pm
ikke wrote:I tried to do this, but an Hreg tool has Errors.
It don't works ...
Do you have VS2008 installed on your system?
Are the net35 assemblies installed in the new folder name you chose?
ikke
Post by ikke » Fri Feb 21, 2014 6:53 am
No
Yes
I' ve written ... again ...
All runs on Windows 8.
Post by Christopher » Fri Feb 21, 2014 9:27 am
ikke wrote:Do you have VS2008 installed on your system?
No
Yes
I don't think there's a problem here. If you have all the assemblies you need in the net35 and net45 folders then you will be able to use all of them in VS2012 on Win8.
Are you able to use both the net35 and net45 assemblies you need? If not, could you please give me details of the problems you're experiencing?
ikke
Post by ikke » Fri Feb 21, 2014 10:16 am
We use
We need both Framework 3.5 and 4.5 for VS2012 ( 'Windows 8' ) !
Error ..
Post by Christopher » Fri Feb 21, 2014 10:23 am
ikke wrote:We use
Error ..
Does this error occur if you run the VS2012 as "run as Administrator"?
If the error doesn't occur when you run the VS2012 IDE as "run as Administrator", then please do so for now. This is a known issue in the binaries you have and has already been fixed; the fix will become available in a new maintenance release due out within the next two or three working days.
Sorry for any inconvenience caused.
ikke
Post by ikke » Fri Feb 21, 2014 10:32 am
No
I hope...
Can i hope ?
Do you read the whole posts of the topic ?
I'm waiting ... for the next release !
