TeeChart for .NET v2017 [14 MAR 2017] does not install
TeeChart for .NET v2017 [14 MAR 2017] RELEASE 4.1.2017.03140 creates an error message when running the installer, see attachment
- Teechart_2017.png (10.33 KiB) Viewed 14039 times
- Guru
Re: TeeChart for .NET v2017 [14 MAR 2017] does not install
We are sorry to hear you having issues installing the latest version of TeeChart on your machine. A couple of questions:
1) which version of Windows are you running?
2) are you installing TeeChart into a unique folder, that is, a folder that does not already exist on your machine?
3) do you have an internet connection?
4) are you using a proxy to connect to the internet?
5) is your licence up to date?
1. Windows 8.1 english
2. the folder c:\Program Files (x86)\Steema Software\Steema TeeChart for .NET 2017 4.1.2017.03140\ gets created (it did not exist at the start of the installation), and a Utils subdirectory is also there.
3. yes
4. no
5. yes, I suppose, I could download the non eval version with the license number I put into the installation dialog
I'll try again now after a reboot
3. yes
4. no
It did not work after a reboot with no programs running and no "Steema Software" directory in the install folder
The same problem occured when I tried on a second PC with Windows 8.1 64 bit
It works on windows 7 64 bit
except that files are missing for the .NET 4.6.2 64 bit install
- Guru
Yes, apologies for this error, it does seem that most of these files are missing. You will be able to use the .NET 4.6 x64 files as a replacement, given that they are (or would be) identical in content to the .NET 4.6.2 files.mcs wrote:except that files are missing for the .NET 4.6.2 64 bit install
