The top outer border does not appear.
goodsj
Post by goodsj » Thu May 23, 2019 4:17 am
After version updating TeeChart 4.1.2012.1032 ==> 4.2018.11.27
Can you guess what the problem is?
TO
Re: The top outer border does not appear.
Post by Christopher » Thu May 23, 2019 10:41 am
Do you have the Back Wall set to visible? Using the following code works as expected here:
            InitializeChart();
            tChart1.Walls.Back.Visible = true;
            tChart1.Walls.Back.Pen.Color = Color.Red;
goodsj
Post by goodsj » Mon May 27, 2019 6:18 am
Hello.
I tried following the attached code above , but it doesn't work. :|
There is no change..
Do you have any other ideas?
Post by Christopher » Mon May 27, 2019 8:34 am
please find attached a Visual Studio project which correctly replicates the code I gave you in my last post:
WindowsFormsApp1.zip
(218.03 KiB) Downloaded 1356 times
Can you please modify the code in this project and post it back here so I can reproduce your problem on my machine?
goodsj
Post by goodsj » Tue May 28, 2019 10:01 am
It helped solve the problem. Thank you :D :D
