Axis value repeat
Elite
Axis value repeat
Post by Elite » Thu Jun 18, 2020 6:25 am
The line is composed of continuous points. When I zoom the chart, duplicate numbers appear on the axis. How should I avoid this situation.
The normal chart is shown in 2.png, and the zoomed chart is shown in 3.png. The figure below shows some of the data.
Re: Axis value repeat
Post by Christopher » Thu Jun 18, 2020 10:20 am
You can set the ValueFormat of series points and axis label values to any of the Standard or Custom numeric format strings, e.g.
            _tChart.Aspect.View3D = false;
            var fastLine = new FastLine(_tChart.Chart);
            fastLine.Add(1.96583, 0.2855);
            fastLine.Add(1.96667, 0.2825);
            fastLine.Add(1.9675, 0.2795);
            fastLine.Add(1.96833, 0.27683);
            fastLine.Add(1.96917, 0.2745);
            _tChart.Axes.Bottom.Labels.ValueFormat = "N5";
Elite
Post by Elite » Fri Jun 19, 2020 1:59 am
Thanks for your suggestions, the problem was successfully solved.
