Howto make automatic labels of the left axis be a multiple of some value
bairog
Post by bairog » Tue Aug 01, 2023 10:07 am
Hello.
I need to make automatic labels of the left axis be a multiple of 125. And ensure horizontal gridlines to be drawn for every label.
So that my chart would look something like this (depending on the actual Y values):
Re: Howto make automatic labels of the left axis be a multiple of some value
Post by Christopher » Tue Aug 01, 2023 11:06 am
I think this does it for you:
            var line1 = new Line(tChart1.Chart);
            var line2 = new Line(tChart1.Chart);
            var rnd = new Random();
            var max = 900;
            for (int i = 0; i < 50; i++)
                line1.Add(rnd.Next(max));
                line2.Add(rnd.Next(max));
            tChart1.Axes.Left.Increment = 125;
            tChart1.Axes.Left.Labels.Separation = 1;
            tChart1.Axes.Left.Grid.DrawEvery = 1;
            tChart1.Axes.Left.AutomaticMinimum = false;
            tChart1.Axes.Left.Minimum = 0;
            tChart1.Axes.Left.GetAxisDrawLabel += Left_GetAxisDrawLabel;
        private void Left_GetAxisDrawLabel(object sender, GetAxisDrawLabelEventArgs e)
            e.DrawLabel = e.LabelValue % 125 == 0;
Try changing the value of 'max'.
bairog
Post by bairog » Tue Aug 01, 2023 11:38 am
Thank you. That is exactly what I need. Only one question left: what does tChart1.Axes.Left.Labels.Separation = 1; stand for? I see no changes on a chart when adjusting that value (I've tried 2, 3, 5 and 10).
Post by Christopher » Tue Aug 01, 2023 2:07 pm
in theory it:
Screenshot from 2023-08-01 15-45-53.png (17.83 KiB) Viewed 142286 times
but it doesn't seem to work very well. What does work is setting max to a high value (e.g. 9000) and setting Separation to 0—here we can see that it leaves no minimum distance, as it should.
bairog
Post by bairog » Wed Aug 02, 2023 5:23 am
I guess you have a TeeChart.xml file. Could you share it so I don't have to go online every time I need a property description. Thank you.
Post by Christopher » Wed Aug 02, 2023 7:48 am
There's a Steema.TeeChart.chm file shipped in the TeeChart NuGet packages which has the xml documentation compiled into it. This is what we would suggest you use for 'offline' API documentation.
Screenshot from 2023-08-02 09-46-43.png (102.4 KiB) Viewed 142249 times
bairog
Post by bairog » Wed Aug 02, 2023 8:05 am
But I would like to see function/property description right into IntelliSense. Could you share TeeChart.xml please.
bairog
Post by bairog » Wed Aug 02, 2023 8:10 am
I have done further testing and found that your code does not always work correctly. I you change 125 to 350 and set max = 8000 - it is ok:
But you set max = 9000 (and more) - most labels are not multiples of 350:
I've expected auto labels to be set to a multiple of 350 (for example 0, 1750, 3500, 5250, 7000 and 8750). Are there any workarounds?
Post by Christopher » Thu Aug 03, 2023 7:52 am
for finer control, you can use the GetNextAxisLabel event, e.g.
        const int _increment = 350;
        const int _max = 20000;
                line1.Add(rnd.Next(_max));
                line2.Add(rnd.Next(_max));
            tChart1.Axes.Left.Increment = _increment;
            tChart1.GetNextAxisLabel += TChart1_GetNextAxisLabel;
        protected override void OnResize(EventArgs e)
            base.OnResize(e);
            tChart1.Header.Text = $"v.{Utils.Version}, size: {tChart1.Height}x{tChart1.Width}, increment: {_increment}, max: {_max}";
        private void TChart1_GetNextAxisLabel(object sender, GetNextAxisLabelEventArgs e)
            var multiplier = Utils.Round(tChart1.Axes.Left.Maximum / _increment / 10);
            int GetValue(int index)
                return _increment * multiplier * index;
            if (sender == tChart1.Axes.Left)
                e.Stop = false;
                switch (e.LabelIndex)
                    case 0: e.LabelValue = 0; break;
                    case 1: e.LabelValue = GetValue(1); break;
                    case 2: e.LabelValue = GetValue(2); break;
                    case 3: e.LabelValue = GetValue(3); break;
                    case 4: e.LabelValue = GetValue(4); break;
                    case 5: e.LabelValue = GetValue(5); break;
                    case 6: e.LabelValue = GetValue(6); break;
                    case 7: e.LabelValue = GetValue(7); break;
                    case 8: e.LabelValue = GetValue(8); break;
                    case 9: e.LabelValue = GetValue(9); break;
                    default: e.Stop = true; break;
Screenshot from 2023-08-03 09-50-40.png (261.52 KiB) Viewed 142221 times
I'm working on getting the xml file to you and will do so when I can.
Post by Christopher » Thu Aug 03, 2023 8:34 am
A more generic solution would be:
            var max_labels = 20;
            var num = Utils.Round(_max / _increment);
            num = num >= max_labels ? max_labels : num;
            var multiplier = Utils.Round(_max / _increment / num);
                e.Stop = false;
                if(e.LabelIndex <= num)
                    e.LabelValue = GetValue(e.LabelIndex);
                    e.Stop = true;
Screenshot from 2023-08-03 10-34-03.png (265.58 KiB) Viewed 142216 times
Post by Christopher » Thu Aug 03, 2023 3:11 pm
I've uploaded new NuGet packages containing the necessary xml documentation comments—they are only needed in .NET Framework, according to my tests, as Visual Studio is somehow able to read these comments directly from .NET Core assemblies without the need for the xml file.
bairog
Post by bairog » Fri Aug 04, 2023 7:00 am
Your code is not working very well when _max / _increment is close to a multiple of max_labels but is slightly less.
In your specific example (max_labels = 20 and _increment = 175) you can just set _max = 13900 (13900 / 175 = 79.428) and get the following picture (there is a big gap between the last label and left axis actual maximum):
I have tested some workarounds and the best I have come up with is changing _multiplier formula from Utils.Round(_max / _increment / _num) to (Int32)Math.Round((Double)_max / _increment / _num). With this approach, a greater multiplier is chosen in 50% cases.
So the situation I've decribed (max_labels = 20, _increment = 175 and _max = 13900) becomes:
My approach is not always perfect: when (Double)_max / _increment / _num is close to n.5 but slightly less there is same gap (but it is 2 times smaller). For example for _max = 12200 (12200/175/20 = 3.485, so _multiplier is still 3) I get the following picture:
If you have any ideas how to further improve my adjusted algorithm - please share it. Thank you.
Post by Christopher » Fri Aug 04, 2023 8:03 am
How about:
            var mod = _max % _increment;
            var local_max = _max;
            if(mod != 0)
                local_max = _max + (_increment - mod);
            var num = Utils.Round(local_max / _increment);
            var multiplier = Utils.Round(num / max_labels);
                e.Stop = false;
                    e.Stop = true;
bairog
Post by bairog » Fri Aug 04, 2023 8:40 am
Unfortunately with this code labels count can greatly exceed max_labels value. For example for _max = 5300 the are 30 labels:
Post by Christopher » Fri Aug 04, 2023 8:49 am
Yes, that's true. But I'm sure you get the idea now of what the TeeChart possibilities are, and so can adapt your code to them.
