Template Import Crashing - Marks.FollowSeriesColor and Cursor Tools
akshobrao
Post by akshobrao » Tue Nov 07, 2023 2:14 pm
Visual Studio 2022
.NET Framework 4.8
Steema.TeeChart.net Version 4.2023.11.6
I am exporting a template and trying to import it back and it crashing. There are two pieces of code which seem to crash the loading of the template. First is line.Marks.FollowSeriesColor = true in the code below and the second is tChart1.Tools.Add(new Steema.TeeChart.Tools.CursorTool()); The code is below and i have commented out those two lines and it seems to work. When adding each line it crashes.
		Steema.TeeChart.TChart tChart1;
			this.Controls.Add(tChart1);
			tChart1.Dock = DockStyle.Top;
			InitializeChart();
			tChart1.Chart.Header.Visible = true;
			Line line = new Line();
			line.Stairs = true;
			line.VertAxis = VerticalAxis.Left;
			//line.Marks.FollowSeriesColor = true;
			tChart1.Series.Add(line);
			//tChart1.Tools.Add(new Steema.TeeChart.Tools.CursorTool());
			File.Delete("template.json");
			tChart1.Export.Template.IncludeData = false;
			tChart1.Export.Template.Save("template.json");
			tChart1.Import.Template.Load("template.json");
			tChart1.Refresh();
Re: Template Import Crashing - Marks.FollowSeriesColor and Cursor Tools
Post by Marc » Wed Nov 08, 2023 7:12 am
Using your test code in a NET 4.8 project, I am unable to reproduce the problem. The template loads correctly, respecting the two code lines:
I have tested with TeeChart release 4.2023.11.6 in VSNet2019 and VSNet2022..
If you are able to send us a sample project that reproduces the issue, we'll check it for other elements/causes.
With thanks.
akshobrao
Post by akshobrao » Wed Nov 08, 2023 1:59 pm
Hi Marc,
It seems to crash here. I have attached screenshots when running in debug mode where it crashes. I created a winforms application with these files in it. Let me know if you can reproduce it with this.
Files.zip
(3.29 KiB) Downloaded 2954 times
Post by Marc » Wed Nov 08, 2023 4:50 pm
Thanks you for the extra info. I can reproduce the error in a fresh project. My test project may be hanging on to a cached-package reference; I'm checking for differences and cause.
Post by Marc » Tue Nov 14, 2023 10:02 am
As a follow-up, A fix has been applied to TeeChart code to be included with the next update release.
