The above figure shows the position of the labels when Axis4. Labels. Angle=315
The following figure shows the position of the labels when Axis4. Labels. Angle=270
How to adjust the position of labels when Axis4. Labels. Angle=315 downwards and rightward
Position setting of coordinate axis labels
- 2.png (25.48 KiB) Viewed 31803 times
- 1.png (22.68 KiB) Viewed 31803 times
Re: Position setting of coordinate axis labels
Thanks for feedback. Which version of "TeeChart" and "Visual Studio" are you using?
Ruben
Ruben
TeeChart: Steema TeeChart for .NET Source Code 2017 4.1.2017.02140
VS2019 [ VB.NET ]
VS2019 [ VB.NET ]
VS2019 [ VB.NET +.NET Framework 4.6.2 ]
I am a legitimate registered user of Steema TeeChart for NET Source Code 2017 4.1.2017.02140. I purchased this version for $2400 at that time. I have been asking for a month now. Can the official answer my question
Apologies for the delay replying. Currently, non-regular angles, (not 0,90,180,270), are not correctly rendering distance from the axis. We are reviewing the code related to this area.
The issue has been resolved (issues #2651]) and the solution will be included with the next TeeChart update.
I have ported this code back into the relevant method for the sourcecode version, 4.1.2017.02140, and although I am unable to test all possible usage scenarios for this version, it should work for you if you replace this entire method in the Axis.cs unit.:
Alternatively, you can upgrade to the latest version of TeeChart to access the modification directly.
Code for the method:DrawAxisLabel(ChartFont f, int x, int y, int angle, string st, TextShape format, bool isTitle)
/// <summary>
/// Draws Axis Label (string) in font f at specified X,Y co-ordinate at Angle.
/// </summary>
#if WPF || SILVERLIGHT || STORE
protected internal void DrawAxisLabel(ChartFont f, double x, double y, int angle, string st, TextShape format, bool isTitle)
#else
protected internal void DrawAxisLabel(ChartFont f, int x, int y, int angle, string st, TextShape format, bool isTitle)
#endif
bool is3D = chart.aspect.view3D;
TextAlignment tmpAlign, tmpAlign2;
Drawing.Graphics3D g = chart.graphics3D;
TextAlignment OldStrAlign = g.TextAlign;
#else
StringAlignment tmpAlign, tmpAlign2;
StringAlignment OldStrAlign = g.TextAlign;
#endif
if (format == null)
format = Labels;
f = format.Font;
g.Font = f;
int intHorizontal = horizontal ? 1 : 0;
int intOtherSide = otherSide ? 1 : 0;
int notIntOtherSide = otherSide ? 0 : 1;
int tmpFontHeight = g.FontHeight;
double tmpH = tmpFontHeight / 2;
double tmpZ = iZPos;
#else
int tmpH = tmpFontHeight / 2;
int tmpZ = iZPos;
#endif
int n = NumTextLines(st);
int delta = tmpFontHeight;
if (horizontal && otherSide)
if ((isTitle) && (is3D) && (!chart.aspect.orthogonal))
tmpZ = MaxLabelsWidth() + chart.aspect.Width3D;
if ((angle > 90) && (angle <= 180))
y = isTitle ? y : y + delta;
tmpAlign = TextAlignment.Center;
#else
tmpAlign = StringAlignment.Center;
#endif
else if ((angle > 0) && (angle <= 90))
x = isTitle ? x : x - delta;
if (!isTitle) x = x - (delta * (n) / 2);
if (this.Labels.Align == AxisLabelAlign.Default)
tmpAlign = TextAlignment.Left;
#else
tmpAlign = StringAlignment.Near;
#endif
y = y - this.MaxLabelsWidth();
tmpAlign = TextAlignment.Right;
#else
tmpAlign = StringAlignment.Far;
#endif
else if ((angle > 180) && (angle <= 270))
if (!isTitle) x = x + delta + (delta * (n) / 2);
#else
#endif
#else
#endif
y = y - delta * (n + 1);
#else
#endif
else if (horizontal)
tmpZ = -MaxLabelsWidth();
#if WPF || SILVERLIGHT || STORE || PORTABLE
#else
if (Labels.Align == AxisLabelAlign.Default)
y += MaxLabelsWidth();
#endif
x = x - delta;
x = x - (delta * (n) / 4);
#else
#endif
y = y + this.MaxLabelsWidth();
#else
#endif
#else
#endif
#else
#endif
else if (angle == 0)
y = y - delta;
#else
#endif
#if iOS
if (!isTitle)
#endif
#elif ANDROID
tmpAlign = Android.Graphics.Paint.Align.Center;
#elif iOS
tmpAlign = CTTextAlignment.Center;
#else
#endif
else if (otherSide)
tmpZ = chart.aspect.Width3D + MaxLabelsWidth();
if (angle == 0)
y -= delta;
y -= (delta * (n)) / 2;
#else
#endif
x = x + this.MaxLabelsWidth();
#else
#endif
else if ((angle > 270) && (angle < 360))
else if ((angle > 90) && (angle <= 180))
y += delta;
y += (delta * (n)) / 2;
#else
#endif
#else
#endif
x -= delta;
#else
#endif
x += delta * (n + 1);
#else
#endif
if (((angle > 270) && (angle <= 360)) || (angle == 0))
y -= delta;
#else
#endif
x = x - this.MaxLabelsWidth();
#else
#endif
else if ((angle > 270) && (angle <= 360))
#else
#endif
#else
#endif
y += delta;
#else
#endif
#else
#endif
x -= delta * (n + 1);
#else
#endif
x += delta;
#else
#endif
int tmpNum;
int tmpSize = Utils.Round(g.TextWidth("W") / 4.0F); //4 instead 2 so the margin don't be so high
format.Left = x;
format.Top = y + delta;
double tmpW = chart.MultiLineTextWidth(st, out tmpNum, format.TextFormat == TextFormat.Html);
#else
int tmpW = chart.MultiLineTextWidth(st, out tmpNum, format.TextFormat == TextFormat.Html);
#endif
tmpH = tmpFontHeight * tmpNum;
tmpAlign2 = tmpAlign;
format.Bottom = format.Top + tmpH;
format.Right = format.Left + tmpW;
if (tmpAlign2 == TextAlignment.Right)
#else
if (tmpAlign2 == StringAlignment.Far)
#endif
format.Right = format.Left;
format.Left = format.Right - tmpW;
else if (tmpAlign2 == TextAlignment.Center)
#else
else if (tmpAlign2 == StringAlignment.Center)
#endif
tmpW = (format.Right - format.Left) / 2;
format.Right -= tmpW;
format.Left -= tmpW;
format.Left -= tmpSize;
format.Right += tmpSize / 2;
if (tmpZ != 0) format.ShapeBounds = g.CalcRect3D(format.ShapeBounds, tmpZ);
#if !WPF && !SILVERLIGHT && !STORE
int tmpFT = format.Top;
int tmpFH = format.Height;
#else
double tmpFT = format.Top;
double tmpFH = format.Height;
#endif
bool tmpDraw = true;
g.TextAlign = tmpAlign;
int tmpD = delta * n;
string tmpSt = st;
int i;
string tmpSt2 = "";
#if VS2005 && !WPF && !SILVERLIGHT && !REPORTINGSERVICES && !POCKET && !CLIENTPROFILE && !STORE
if ((horizontal) && ((this.chart.Tools.Count > 0) && (hasScrollTool())))
g.ClipRectangle(CalcXPosValue(minimumValue), 0,
CalcXPosValue(maximumValue), Chart.Height);
#endif
DoGetAxisDrawLabel(this, ref x, ref y, ref tmpZ, ref tmpSt, ref tmpDraw);
if (tmpDraw) n = NumTextLines(tmpSt);
if (tmpDraw)
for (int tt = 1; tt <= n; tt++)
double tmpAngle = format.Width / 2;
if (OtherSide)
tmpAngle = tmpAngle - 0.25 * format.Height;
double tmpYDisp = tmpAngle * Math.Abs(Math.Sin(Utils.Deg2Rad(angle)));
if (angle > 0)
format.Bottom = tmpFT;
format.Top = tmpFT + (int)tmpYDisp; // - tmpFH;
if ((angle >= 0) && (angle <= 90))
#if iOS
if (!isTitle)
#endif
if (angle == 90)
x += delta - (tmpFontHeight / 4);
x += delta - (int)(tmpFontHeight / 4 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
format.Left += delta;
format.Right += delta;
if (angle == 180)
x -= format.Width / 2;
x -= (int)(tmpFontHeight / 2 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
y += (int)(tmpFontHeight * Math.Abs(Math.Cos(Utils.Deg2Rad(angle))));
x -= delta;
format.Left -= delta;
format.Right -= delta;
x += (int)(format.Width / 2 * Math.Abs(Math.Cos(Utils.Deg2Rad(angle))));
y += (int)(format.Width / 2 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
format.Top += delta;
format.Bottom += delta;
if (!format.Transparent || hasClicked)
#if SILVERLIGHT || WPF || STORE
if (angle > 0)
RotateTransform rotate = new RotateTransform();
rotate.Angle = 360 - angle;
rotate.CenterX = x;
rotate.CenterY = y;
double tmpFW = format.Width;
format.Left += tmpFW / 2.0;
format.Right += tmpFW / 2.0;
#if STORE
format.ShapePolygonBounds = new Point[] { rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)),
rotate.TransformPoint(new Point(format.ShapeBounds.Right, format.ShapeBounds.Top)),
rotate.TransformPoint(new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom)),
rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom)),
rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top))};
#else
format.ShapePolygonBounds = new Point[] { rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)),
rotate.Transform(new Point(format.ShapeBounds.Right, format.ShapeBounds.Top)),
rotate.Transform(new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom)),
rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom)),
rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top))};
#endif
g.Brush = format.Brush;
g.Pen = format.Pen;
g.Polygon(format.ShapePolygonBounds);
format.DrawRectRotated(g, format.ShapeBounds, 0, tmpZ);
#elif !POCKET
Matrix m = g.GDIplusCanvas.Transform;
m.RotateAt((float)(360 - angle), new Point(x, y));
g.GDIplusCanvas.MultiplyTransform(m);
format.ShapePolygonBounds = new Point[] { new Point(format.ShapeBounds.Left, format.ShapeBounds.Top), new Point(format.ShapeBounds.Right, format.ShapeBounds.Top),
new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom), new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom), new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)};
m.TransformPoints(format.ShapePolygonBounds);
g.GDIplusCanvas.ResetTransform();
#endif
labels.labelPos.Add(format.ShapePolygonBounds);
labels.labelPos.Add(format.ShapeBounds);
i = tmpSt.IndexOf(Texts.LineSeparator);
tmpSt2 = (i != -1) ? tmpSt.Substring(0, i) : tmpSt;
if (angle == 0)
y += delta;
g.Font = f;
if (labels.Exponent)
DrawExponentLabel(x, y, tmpZ, tmpSt2, angle);
else if (is3D)
g.TextOut(x, y, tmpZ, tmpSt2, format.TextFormat == TextFormat.Html);
g.TextOut(f, x, y, tmpSt2, format.TextFormat == TextFormat.Html);
if (labels.Exponent && (angle == 90 || angle == 270))
g.RotateLabel(x, y, tmpZ, tmpSt2, angle, format.TextFormat == TextFormat.Html);
if (i >= 0) tmpSt = tmpSt.Remove(0, i + 1);
g.TextAlign = OldStrAlign;
