Adding multiple points after Template.Load crashes
akshobrao
Post by akshobrao » Tue Apr 16, 2024 7:09 pm
Visual Studio 2022
Target framework .NET 6.0
Steema.TeeChart.net Version 4.2024.4.12
After a template is imported using the Load Command, it crashes after adding more the one point to the series. It crashes in 2nd LoadData. This example works if only 1 point is added.
Steema.TeeChart.TChart tChart1;
this.Controls.Add(tChart1);
tChart1.Axes.Bottom.Visible = true;
tChart1.Axes.Left.Visible = true;
tChart1.Axes.Right.Visible = false;
Line line = new Line();
tChart1.Chart.Series.Add(line);
LoadData();
TemplateExport template = tChart1.Export.Template;
template.IncludeData = false;
tChart1.Export.Template.Save("template.json");
tChart1.Import.Template.Load("template.json");
LoadData();
private void LoadData()
var line = tChart1.Chart.Series[0];
line.Add(1, 1);
line.Add(2, 2);
line.Add(3, 3);
Screenshot 2024-04-16 140524.png (29.3 KiB) Viewed 36909 times
Edu
Re: Adding multiple points after Template.Load crashes
Post by Edu » Thu Apr 18, 2024 8:10 am
Thank you for the issue report. We are investigating possible causes.
Edu
akshobrao
Post by akshobrao » Tue May 14, 2024 5:51 pm
Any update on this issue?
Edu
Post by Edu » Wed May 15, 2024 7:13 am
Hi, a fix has been made that will be included with the next update, due for imminent release this week.
Edu
Edu
akshobrao
Post by akshobrao » Wed May 15, 2024 12:39 pm
Thanks for letting me know.
Edu
Post by Edu » Fri May 17, 2024 7:26 am
Hi, the TeeChart nuget has been updated. The version includes a fix to the problem you have reported.
https://www.nuget.org/packages/Steema.T ... .2024.5.16
Edu
akshobrao
Post by akshobrao » Mon May 20, 2024 2:56 pm
Thanks for that. Tried it out and is working now.
