Programmatic Chart Creation and Saving to Disk
jzarech
Post by jzarech » Sun May 05, 2024 3:26 am
Hi Fellow TChart Devs,
I was curious if there's an example of programmatically generating charts using TChart.Net then saving chart pic to a disk file.
In other words to use in an API without WinForms.
I searched here and on YouTube and didn't find anything.
It would save me a lot of time.
ja
Edu
Re: Programmatic Chart Creation and Saving to Disk
Post by Edu » Tue May 07, 2024 10:46 am
here's a quick example of what you're requesting, made with a Console App and .NET 6.0.
using Steema;
using Steema.TeeChart;
using Steema.TeeChart.Styles;
namespace ConsoleApp1
    internal class Program
        static void Main(string[] args)
            //Create chart
            TChart myChart = new TChart();
            //Create your series and populate them and add Series to Chart
            Line myLine = new Line();
            myChart.Series.Add(myLine);
            for (int i = 0; i<5; i++)
                myLine.Add(i, i*2);
            // (Optional) Customization
            myLine.Marks.Visible = true;
            myLine.ColorEach = true;
            myChart.Export.Image.PNG.Width = 1500;
            myChart.Export.Image.PNG.Height = 1500;
            //Finally, export.
            string myPath = "myChart.png";
            myChart.Export.Image.PNG.Save(myPath);
Edu
Edu
jzarech
Post by jzarech » Tue May 07, 2024 2:04 pm
Thanks so much!
jzarech
Post by jzarech » Sun May 12, 2024 4:13 pm
So I tried the code and it works but I'm having trouble writing custom text out to "graphics" object - normally this text is written in the "BeforeDraw" event when using WinForms - but in API style no events are thrown so I thought I could access the "g" graphics object passed in the DrawEvents and draw but I get an error -- see picture below - System.NullReferenceException on the g.TextOut line of code:
jzarech
Post by jzarech » Sun May 12, 2024 4:27 pm
Nevermind - doyyy -
I just wired up the API Version of TChart to its AfterDraw event handler and did the drawing the same as the WinForms Version and it works -- thanks for your help!
