I am developing WPF web application that uses TeeChart. TeeChart requires full trust, which I would think significantly limits deployment as a web application. Will this limitation be removed in the near future?
Kent
Deploying a WPF web application requires full trust
Re: Deploying a WPF web application requires full trust
I think this may have something to do with the fact that the "Allow unsafe code" checkbox was checked in the teechart.wpf project. I've unchecked this, as it is not necessary, and this change will be available in the next maintenance release due out within the next ten days or so.BlueMonkey wrote: I am developing WPF web application that uses TeeChart. TeeChart requires full trust, which I would think significantly limits deployment as a web application. Will this limitation be removed in the near future?
Thank you!
http://groups.google.com
http://codenewsfast.com/
