Events available related to AxisScroll
VarUser
Post by VarUser » Tue Jun 14, 2011 9:14 am
I am using AxisScroll in the chart.
Is there any event which is raised when I drag my mouse over the axis. The axis moves automatically but I want to do some thing more when user will drag mouse over the axis.
Is there any way by which I can detect that user is scrolling using AxisScroll.
- JC
Re: Events available related to AxisScroll
Post by Sandra » Wed Jun 15, 2011 2:53 pm
Hello VarUser,
You can do something using Chart events, as next code, where use AxesClick event to detected axes work as you want work:
        private Steema.TeeChart.Styles.Bar bar1;
        private Steema.TeeChart.Tools.AxisScroll axisScroll1;
        void InitializeChart()
            bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar1.FillSampleValues();
            axisScroll1 = new Steema.TeeChart.Tools.AxisScroll(tChart1.Chart);
            tChart1.ClickAxis += new MouseEventHandler(tChart1_ClickAxis);
        void tChart1_ClickAxis(object sender, MouseEventArgs e)
            if (tChart1.Axes.Bottom == sender)
                axisScroll1.Active = true;
                axisScroll1.Active = false;
Could you confirm us if previous code works as you expected?
I hope will helps.
VarUser
Post by VarUser » Thu Jun 16, 2011 7:00 am
Hi Sandra
Thanks for your reply.
One related query.
We have handled tChart.Zoomed event and when we use AxisScroll to scroll the data, this event handler for Zoomed is un-necessarily getting called.
This means that even when we scroll the data(using AxisScroll) zoomed event is raised. Is there any way to get rid of this.
- JC
Post by Sandra » Fri Jun 17, 2011 8:56 am
Hello VarUser,
I have made simple project using Zoomed and Scroll events where respectively disable and enable AxisScroll:
            tChart1.Scroll += new EventHandler(tChart1_Scroll);
            tChart1.Zoomed += new EventHandler(tChart1_Zoomed);
        void tChart1_Zoomed(object sender, EventArgs e)
        void tChart1_Scroll(object sender, EventArgs e)
VarUser
Post by VarUser » Wed Jun 22, 2011 9:21 am
Thanks for the reply
- JC
