some questions about TeeChart
Posted: Mon Jan 21, 2013 9:34 am
when we use the Teechart there is some questions can you help me? please see the Attachment thanks!
Steema Software - Customer Support Forums
http://www.teechart.net/support/
If you want get the values of a determinate selection values. I recommend you taking a look in this link where are discussing about this topic. If you have any problems, please let me know.Can I Marquee the chart and get the Sequence data (please see the picturec)?
I want to get this data and draw a new chart how can I do
Yes, I recommend you taking a look in the All features\Welcome !\Chart styles\Financial\Point and Figure to know as you do to create this type of Financial Charts.2:dose Teechart support this Type of Chart? Thanks!
private Steema.TeeChart.Tools.ZoomTool tool1;
private System.IO.MemoryStream tmpChart;
protected void Page_Load(object sender, System.EventArgs e)
Steema.TeeChart.Chart ch1 = WebChart1.Chart;
tmpChart = new System.IO.MemoryStream();
if (Session["ch1"] == null)
ch1.AutoRepaint = false;
ch1.Aspect.View3D = false;
//Tool Zoom
ch1.Tools.Add(new Steema.TeeChart.Tools.ZoomTool(WebChart1.Chart));
tool1.ZoomPenColor = System.Drawing.Color.OliveDrab;
ch1.Panel.Gradient.Visible = false;
ch1.Walls.Visible = false;
ch1.Series.Add(new Steema.TeeChart.Styles.Points());
ch1[0].FillSampleValues();
ch1[1].FillSampleValues();
ch1.Export.Template.Save(tmpChart);
//save template to a Session variable
Session.Add("ch1", tmpChart);
//retrieve the session stored Chart
tmpChart = (System.IO.MemoryStream)Session["ch1"];
//set the Stream position to 0 as the last read/write
//will have moved the position to the end of the stream
tmpChart.Position = 0;
//import saved Chart
WebChart1.Chart.Import.Template.Load(tmpChart);
System.Drawing.Bitmap bmp = WebChart1.Chart.Bitmap((int)WebChart1.Width.Value, (int)WebChart1.Height.Value);
myMethod();
//If you want use zoom you only need uncoment CheckZoom
// CheckZoom(WebChart1);
//Use My method to get the rectangle zoom coordinates.
private void myMethod()
Hashtable ht = getZoomArgs(Request);
int X0 = Convert.ToInt32(ht["x0"]);
int Y0 = Convert.ToInt32(ht["y0"]);
int X1 = Convert.ToInt32(ht["x1"]);
int Y1 = Convert.ToInt32(ht["y1"]);
ListBox1.Items.Clear();
if ((X0 != -1) && (Y0 != -1))
foreach (Steema.TeeChart.Styles.Series s in WebChart1.Chart.Series)
for (int i = 0; i < s.Count; i++)
if (CheckSeriesPoints(s, i, X0, Y0, X1, Y1))
ListBox1.Items.Add("Series:"+s.Title+"Point " + i.ToString() + ": " + s.XValues[i].ToString() +
", " + s.YValues[i].ToString());
//CheckSeriesPoint is in the rectangle or not.
private bool CheckSeriesPoints(Steema.TeeChart.Styles.Series s, int index, int X0,int Y0, int X1, int Y1)
return ((s.CalcXPos(index) >= X0) && (s.CalcXPos(index) <= X1) && (s.CalcYPos(index) >= Y0) && (s.CalcYPos(index) <= Y1));
//Do zoom.
private void CheckZoom(Steema.TeeChart.Web.WebChart wChart)
System.Collections.ArrayList zoomedState = (System.Collections.ArrayList)Session[Request.QueryString["filename"] + "Zoomed"];
System.Drawing.Bitmap bmp = WebChart1.Chart.Bitmap((int)wChart.Width.Value, (int)wChart.Height.Value);
if (wChart.Chart.Tools.Count > 0)
zoomedState = ((Steema.TeeChart.Tools.ZoomTool)wChart.Chart.Tools[0]).SetCurrentZoom(Request, zoomedState);
if (zoomedState != null)
Session.Add(Request.QueryString["filename"] + "Zoomed", zoomedState);
Session.Remove(Request.QueryString["filename"] + "Zoomed");
//Need to get arguments of Zoom tool to allow you calculate rectangle.
protected Hashtable getZoomArgs(HttpRequest r)
Hashtable argumentList = new Hashtable();
if ((r.Params["__EVENTARGUMENT"] != null) && (r.Params["__EVENTARGUMENT"].Length > 0))
char[] pairs = new char[1] { ';' };
char[] vals = new char[1] { '$' };
String[] varpairs = r.Params["__EVENTARGUMENT"].Split(pairs);
foreach (string s in varpairs)
if (s.IndexOf("$") != -1)
argumentList.Add(s.Split(vals)[0], s.Split(vals)[1]);
return argumentList;
