Gantt series performance
Jeremy Johnson
Post by Jeremy Johnson » Thu Mar 21, 2013 6:26 pm
I have a Gantt series that will ultimately need to display thousands of bars. With only ~600 bars, drawing is taking upwards of 15 seconds.
I just need the Gantt to display simple, plain boxes such as those in the attached image. However, when my entire data set is loaded there will be many thousand of them.
Any suggestions to improve drawing performance? (I'm aware I could do some sort of down sampling, which I will do, but I need better chart performance at least with hundreds of boxes).\
graph detail.png (5.08 KiB) Viewed 11435 times
Re: Gantt series performance
Post by Sandra » Fri Mar 22, 2013 1:12 pm
Hello Jeremy Johnson,
Would be very grateful if you could send us a simple project because we can reproduce exactly your problem here?
Jeremy Johnson
Post by Jeremy Johnson » Fri Mar 22, 2013 10:13 pm
Code is ready to go. Where shall I send it? Thanks!
Post by Narcís » Mon Mar 25, 2013 7:59 am
Hi Jeremy,
You can either attach it to a forums post or send it to http://www.steema.net/upload/
Jeremy Johnson
Post by Jeremy Johnson » Mon Mar 25, 2013 9:42 pm
Thanks, the sample code has been uploaded. (Poor Gantt Performance Test.zip)
Post by Sandra » Tue Mar 26, 2013 4:06 pm
Ok I have achieved improve your performance disabling the PenConnection of Gantt Series. I recommend you, add it after adding values in the gantt as I do in your code:
            // Add many bars to the Gantt series
            //this kills performance.  i need to support large data sets, and even with down sampling I really would like to get decent performance with thousands of bars.
            for (int i = 0; i < 500; i++)
                _activitySeries.Add(startTime.AddSeconds(i * 10), 2,  Colors.Red);
            _activitySeries.Add(startTime.AddSeconds(iOffPanelStart * secBetweenTicks), startTime.AddSeconds(iAbsentStart * secBetweenTicks), 1, _color2);
            _activitySeries.Add(startTime.AddSeconds(iAbsentStart * secBetweenTicks), startTime.AddSeconds(iAbsentEnd * secBetweenTicks), 0, _color3);
            _activitySeries.ConnectingPen.Visible = false;
Could you tell us if it works in your end?
I hope will helps.
Jeremy Johnson
Post by Jeremy Johnson » Wed Apr 03, 2013 3:49 pm
Thanks! This has improved execution time tremendously.
However, the memory usage by the Gantt series is huge. With more than around 12000 items, I get an out-of-memory exception. Memory usage in my sample app is around 850MB with 10000 items.
Is there anything that can be done to reduce memory usage?
Jeremy
Post by Sandra » Fri Apr 05, 2013 11:07 am
Hello Jeremy,
Ok, I have made a simple modification that consist in add start and end coordinates and color, therefore, use correctly method add of Gantt series. Please see in the attached project the modification code and check if performance is improved and out-of-memory exception disappears in your machine. If you have any problems please let me know.
(34.51 KiB) Downloaded 548 times
Jeremy Johnson
Post by Jeremy Johnson » Fri Apr 05, 2013 3:21 pm
Thanks, Sandra! You've saved the day.
Memory usage is now a slim 50MB for 10,000 items.
