How to add/show scrollviewer for teechart
gilbert
Post by gilbert » Tue Apr 30, 2013 2:07 pm
I am working on teechart using line series to display csv file data.
My requirement is to scroll the teechart line series as they go beyond the x axis and if I move scrollviewer forward, then current line series should be shown.
I can achieve it using AxisArrow on x-axis which will result displaying left arrow and right arrow on x axis and the data can be scrolled back and forth once we click on arrow.
But I would like to have a scrollviewer down the teechart and should show the same behaviour with its mousewheel/scroll changed.
I would like to show the scrollviewer for the teechart and achieve the scrolling functionality for the teechart lines.
Please help me to solve the problem.
Archana
Re: How to add/show scrollviewer for teechart
Post by Sandra » Thu May 02, 2013 3:27 pm
Hello Archana,
Sorry for the delay. I think you could use a similar code as All Features\Welcome !\Axes\Opaque zones. For this reason, I have made a simple code in Wpf based in this example, but using a scrollviewer. Is possible you need adjust the ScrollChange event values.
C# code
            tChart1.Series.Add(new Steema.TeeChart.WPF.Styles.FastLine()).FillSampleValues(100);
           scrollviewer1.HorizontalScrollBarVisibility = ScrollBarVisibility.Visible;
           scrollviewer1.ScrollChanged += scrollviewer1_ScrollChanged;
           tChart1.Axes.Bottom.SetMinMax(0, 50);
        void scrollviewer1_ScrollChanged(object sender, ScrollChangedEventArgs e)
           double tmp = 0.01 * ((int)e.HorizontalChange-10) * (tChart1[0].XValues.Maximum - tChart1[0].XValues.Minimum);
           tChart1[0].GetHorizAxis.SetMinMax(tChart1[0].XValues.Maximum + tmp, tChart1[0].XValues.Minimum + tmp);
xaml code
   <ScrollViewer HorizontalAlignment="Left" Height="600" VerticalAlignment="Bottom" Width="800" Name="scrollviewer1">
        <WPF:TChart Height="600" Width="1000" x:Name="tChart1"/>
    </ScrollViewer>
Can you tell us if previous code help you achieve as you want?
gilbert
Post by gilbert » Fri May 03, 2013 5:13 am
Hi Sandra,
Thank you for the reply.
In this case,Horizontal scrollviewer is applying for teechart control.
But I would like to have a scrollbar/scrollviewer for the line series in teechart control i.e., the live data(line series) flowing in teechart control should scroll back and forward on the scrolling event.
I just tried below link to achieve it.
http://www.teechart.net/support/viewtop ... f=4&t=1924
Which works for the series in teechart.
Post by Sandra » Fri May 03, 2013 2:00 pm
Hello Archana,
I have modified my code because the line series does scroll. To achieve it, I have used a stackpanel with a size that is three times the size of scrollviewer. After, you only need relate the Axis bottom with scrollviewer and I achieved scrolling line with scrollviewer. I think you can do something as next:
C# MainWindow code:
        public MainWindow()
            InitializeChart();
            scrollviewer1.VerticalScrollBarVisibility = ScrollBarVisibility.Disabled;
            Random Rnd = new Random();
            tChart1.Series.Add(new Steema.TeeChart.WPF.Styles.Line());
            for (int i = 0; i <= 100; i++)
                tChart1.Series[0].Add(i, Rnd.Next(100), "");
            scrollviewer1.ScrollToHorizontalOffset(0);
        int AxisMax = 0;
        int AxisMin = 100;
        private void scrollviewer1_ScrollChanged(object sender, ScrollChangedEventArgs e)
            if (e.HorizontalChange< 50)
                tChart1.Axes.Bottom.SetMinMax(AxisMin - (10 -e.HorizontalOffset), AxisMax - (10- e.HorizontalOffset));
                tChart1.Axes.Bottom.SetMinMax(AxisMin + (e.HorizontalOffset - 10), AxisMax + (e.HorizontalOffset - 10));
            tChart1.Invalidate();
Xaml MainWindow code:
    <Grid Width="692.537" Margin="0,0,0,0">
        <WPF:TChart Height="451.865" Width="685" x:Name="tChart1" />
        <ScrollViewer   HorizontalAlignment="Left" Height="100"
           Margin="0,0,0,0" VerticalAlignment="Bottom" Width="685"
           ScrollChanged="scrollviewer1_ScrollChanged">
            <StackPanel  Height="0" Width="2055" OverridesDefaultStyle="False" />    <!--<WPF:TChart Height="451.865" Width="685" x:Name="tChart1" />-->
        </ScrollViewer>
    </Grid>
I hope will helps.
gilbert
Post by gilbert » Sat May 04, 2013 9:55 am
Hi Sandra,
I will try the code and let you know.
Thank You.
