WPF TeeChart Rotation Bug
neurosoft
Post by neurosoft » Mon Jul 29, 2013 5:13 am
Hi steema!
I have an annoying bug with rotation of WPF TeeChart. It seems that you don't capture/release mouse when rotation starts/ends. Rotation will be stopped and mouse events won't be handled if the mouse is out of TeeChart borders.
Re: WPF TeeChart Rotation Bug
Post by Sandra » Mon Jul 29, 2013 2:34 pm
Hello neurosoft,
I can not reproduce your problem using next code:
            Steema.TeeChart.WPF.Styles.Line line = new Steema.TeeChart.WPF.Styles.Line(tChart1.Chart);
             line.FillSampleValues(40);
            Steema.TeeChart.WPF.Tools.Rotate rotationTool = new Steema.TeeChart.WPF.Tools.Rotate(tChart1.Chart);
Could you tells us if using my previous code your problem appears? If appears please could you tell us how can reproduce it? If it doesn't appear could you modify my code, because we can reproduce your problem here?
neurosoft
Post by neurosoft » Tue Jul 30, 2013 7:31 am
Yes, the problem appears with your code too. But to reproduce it you should move mouse with pressed button out of TChart (but not out of Window) and then release button.
Try to use the following xaml:
    <Window x:Class="WpfApplication1.MainWindow"
            xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
            xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
            xmlns:tc="clr-namespace:Steema.TeeChart.WPF;assembly=TeeChart.WPF"
            Width="600" Height="400"
            Title="MainWindow">
        <Grid>
            <Grid.RowDefinitions>
                <RowDefinition/>
                <RowDefinition/>
            </Grid.RowDefinitions>
            <tc:TChart Name="tChart1"/>
        </Grid>
    </Window>
Mouse movement should be like this:
Post by Sandra » Tue Jul 30, 2013 3:00 pm
Hello neurosfot,
Thanks for your indication. I have added your request in bug list report with number [TW16016672]. We will try to fix it to upcoming maintenance releases of TeeChartWPF.
