Top Custom Axis Elements are outside chart area
MartinB
Post by MartinB » Thu Aug 08, 2013 4:14 pm
I would like to add a custom axis on top of my color grid graph, but it seems that the labels and the title of this custom axis appears outside the chart area (above the chart title).
I tried to set a different top margin but the only thing it does is adding some space above the chart title, and the axis labels stay above my chart view.
Could you help me please ?
Re: Top Custom Axis Elements are outside chart area
Post by Sandra » Mon Aug 12, 2013 9:34 am
Hello MartinB,
I have made a simple code where I have added a horizontal custom axis top, I have incremented the top margin and I have repositioned the Title of Char and the labels of axis,are in the Chart area always.
  Axis customAxis;
      colorGrid1 = new ColorGrid(tChart1.Chart);
      colorGrid1.FillSampleValues();
      customAxis = new Axis(tChart1.Chart);
      tChart1.Axes.Custom.Add(customAxis);
      customAxis.Horizontal = true;
      colorGrid1.HorizAxis = HorizontalAxis.Both;
      colorGrid1.CustomHorizAxis = customAxis;
      tChart1.Draw();
      customAxis.OtherSide = true;
      tChart1.Panel.MarginUnits = PanelMarginUnits.Pixels;
      tChart1.Panel.MarginTop = 50;
      tChart1.Header.CustomPosition = true;
      tChart1.Header.Left = tChart1.Width / 2;
      tChart1.Header.Top = 0;
      button1.Click +=button1_Click;
Could you please tell us if previous code help you to solve your problem? If it doesn't help please try to arrange for us a simple code where the problem appears, because we can try to solve your problem.
MartinB
Post by MartinB » Mon Aug 12, 2013 12:50 pm
Hello Sandra,
Indeed it is now working better adding these lines :
except the labels I add on the bottom axis disappears.
I tried to only use
but this time , if I call the customAxis.labels.Clear() method and I add another label, I still see a lot of labels on the top custom axis plus my new label.
I would like to only add custom labels on this top axis, how can I do this please ?
Post by Sandra » Mon Aug 12, 2013 3:12 pm
Hello MartinB,
I am afraid if you want use multiple custom axis for one series, you can not do it, because you only can assign for each axis one Series, for this reason, The possibility to assign several horizontal/vertical axes to a series is a request already in the wish-list (TF02010876).
In this point, I think you have two options as a workaround:
First don't use custom axes, but use default Bottom axis and Top axis of Chart as do in next code:
      AddCustomLabels(tChart1.Axes.Top);
      tChart1.Draw();
      button1.Click += button1_Click;
    private void AddCustomLabels(Axis a)
      a.Labels.Items.Clear();
      a.Labels.Items.Add(colorGrid1.XValues[5], "Point 1");
Second, use a auxiliary series and assign custom axis to it. You can do something a next code:
    Axis customAxis;
    Steema.TeeChart.Styles.ColorGrid colorGrid1;
    Steema.TeeChart.Styles.ColorGrid auxiliarygrid;
      auxiliarygrid = new ColorGrid(tChart1.Chart);
      colorGrid1.HorizAxis = HorizontalAxis.Bottom;
      auxiliarygrid.CustomHorizAxis = customAxis;
      auxiliarygrid.ShowInLegend = false;
      AddCustomLabels(customAxis);
      tChart1.Draw();
As you see in both codes I have removed the labels of top axis and add only one label.
MartinB
Post by MartinB » Tue Aug 27, 2013 1:16 pm
The second workaround worked for me, thank you very much.
