Customize ExportEditor
MattG
Post by MattG » Thu Oct 10, 2013 9:45 pm
I'm trying to customize the ExportEditor before displaying it, but nothing I change in DataFormat seems to have any effect on the resultant dialog. Here's what I'm trying:
Steema::TeeChart::Editors::Export::ExportEditor ^ed = gcnew Steema::TeeChart::Editors::Export::ExportEditor(tChart1->Chart);
ed->Text = "Export Plot";
ed->DataFormat->IncludeSeriesTitle = true;
ed->DataFormat->TextLineSeparator = " End of Line\n";
ed->ShowDialog();
So I expected that the Series Title checkbox would be checked, and when I exported to a text file I expected to see " End of Line" at the end of each line. But neither happens. How do I get my customizations to take effect?
Incidentally, setting ed->Text did work as expected.
I'm using C++/CLI .NET 4.0.
Thank you,
Matt
Matt Garrett
CRTech
Boulder, Colorado, USA
Re: Customize ExportEditor
Post by Sandra » Fri Oct 11, 2013 8:44 am
Hello MattG,
Could you please try to send us your complete project because we can reproduce your problem exactly here?
MattG
Post by MattG » Fri Oct 11, 2013 3:13 pm
Hi Sandra,
The attached test project exhibits the behavior. When you click the button to open the ExportEditor, it does not reflect any of the customizations defined before showing it, except ed->Text. For example, if you output the data as a text file, I would expect each line to terminate with " End of Line\n".
Matt
TestExportEditor2.zip
Test project showing problem with ExportEditor customization
(57.98 KiB) Downloaded 1005 times
Matt Garrett
CRTech
Post by Sandra » Mon Oct 14, 2013 3:05 pm
Hello Matt,
Thanks for your project, I can reproduce your problem and I inform your request is in bug list report with number (TF02016738) and we try to fix it to next maintenance releases of TeeChartFor.Net. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
MattG
Post by MattG » Mon Oct 14, 2013 10:51 pm
Thank you Sandra. Can you give me an estimated date for the bug fix?
Matt Garrett
CRTech
Post by Sandra » Tue Oct 15, 2013 9:48 am
Hello Matt,
Good news, I inform you that the bug number TF02016738 is already fixed for next maintenance release of TeeChartFor.net.
MattG
Post by MattG » Fri Jan 17, 2014 5:34 pm
Thanks Sandra, this appears to be working now.
Matt
Matt Garrett
CRTech
