Upgrade installation
I have just installed the upgrade to the newest version, but the component doesn't appear in the toolbar.
Re: Upgrade installation
Hello FuscaG,
If you are using IDEs of Visual Studio VS2003, VS2005, VS2008, VS2010 please see next thread to add the TeeChart components in your toolbox.
If you are using IDE of Visual Studio, VS2012 the TeeChart component should be appears automatically in the toolbox, but, if it doesn't appear, you can do the same in previous suggestion for other IDEs of Visual Studio or go to Menu Tools\extensions and updates and check if Steema TeeChart 2013 Charting control is installed, if it isn't installed, please go to the folder where you install TeeChart, concretely in the folder there is the assembly for .Net Framework 4.5 (C:\Program Files\Steema Software\Steema TeeChart for .NET 2013 4.1.2013.07300\net45\x86) and execute the TeeChart.vsix, this should solve the problem in visual studio 2012.
I hope will helps.
I hope will helps.
| Sandra Pazos / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
