Hi!
How to center or move up/down value in NumericGauge inside Circular gauge?
It is always on top of numeric gauge frame. When size of gauge is small it overlaps frame.
NumericGauge value position inside CircularGaguge
- Screen Shot 2013-10-29 at 4.35.05 PM.png (10.51 KiB) Viewed 9492 times
Re: NumericGauge value position inside CircularGaguge
Hello Thomas,
To change the position of the LinearGauge of your circularGauge you must only set to false, the automatic position as do in next lines of code:
I hope will helps.
Steema.TeeChart.TChart tChart1;
tChart1 = new TChart();
this.Controls.Add(tChart1);
tChart1.Top = 150;
tChart1.Left = 100;
tChart1.Height = 400;
tChart1.Width = 550;
InitializeChart();
Rectangle tmpG;
Steema.TeeChart.Styles.CircularGauge circulargaugeL = new CircularGauge(tChart1.Chart);
circulargaugeL.NumericGauge.Visible = true;
circulargaugeL.Value = 30;
circulargaugeL.AutoValueNumericGauge = false;
circulargaugeL.NumericGauge.Value = 50;
tChart1.Draw();
//Custom postion of NumericGauge:
circulargaugeL.AutoPositionNumericGauge = false;
tmpG = circulargaugeL.NumericGauge.CustomBounds;
tmpG.X = 200;
tmpG.Y = 300;
circulargaugeL.NumericGauge.CustomBounds = tmpG;
void button1_Click(object sender, EventArgs e)
tChart1.ShowEditor();
I hope will helps.
Thanks. It works. But i need something like gauge on image. Can you help?
I can't hide border of numeric gauge (circularGauge.NumericGauge.FaceBrush.Visible = false; not working),
can't change text color (circularGauge.NumericGauge.ValueMarker.Shape.Font.Color not working)
- gauge.png (25.26 KiB) Viewed 9480 times
- Guru
If it is just text you want, maybe the easiest thing to do is this:
This does work, but has to be used in conjunction with:I can't hide border of numeric gauge (circularGauge.NumericGauge.FaceBrush.Visible = false; not working)
series.NumericGauge.ValueMarker.Shape.Transparent = true;
This also works, but has to be used in conjunction with:can't change text color (circularGauge.NumericGauge.ValueMarker.Shape.Font.Color not working)
series.NumericGauge.ValueMarker.UsePalette = false;
Steema.TeeChart.Styles.CircularGauge series;
tChart1.AfterDraw += tChart_AfterDraw;
series = new CircularGauge(tChart1.Chart);
series.FillSampleValues();
series.TotalAngle = 180;
private void tChart_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
g.Font.Color = Color.White;
g.Font.Size = 20;
g.TextOut(g.ChartXCenter - 25, g.ChartYCenter + 70, "303");
