Add Curve Tool to Wish List
I find the line tool and shape tools useful; however I would also like to see a curve tool for drawing curves on charts, if possible.
Re: Add Curve Tool to Wish List
Hello lilo,
If you want to add a Curve in your chart, you can manually add the points to Line or FastLine series using the MouseDown event. You can then improve the resultant Line series aspect with Smoothed property or use Smoothing or Polynomial fitting functions. You can find some examples on how to use those functions in the Demo project: Welcome !\Functions\Extended\Smoothing function or Welcome !\Functions\Extended\Polynomial
I hop will helps.
I hop will helps.
| Sandra Pazos / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
Hi Sandra,
I am using the curves as drawing annotations, not actual charts.
Hello lilo,
Thanks for your concretion. In this point, if you want work as an annotation, you can use Line and FastLine Series as I recommend previously, but setting ShowInLenged property to false, if it doesn't like you, Could you please add your request to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
