multichart to 1 page pdf export?
kp_digi
Post by kp_digi » Tue Mar 25, 2014 5:22 pm
I'm new to using TeeChart so please excuse me if this is an obvious question. I would like to export 3 line charts all to a single page .pdf. I'm able to export 3 charts to 3 separate pages withing the .pdf file but how can I get all 3 charts to display on a single page?
Re: multichart to 1 page pdf export?
Post by Christopher » Wed Mar 26, 2014 9:18 am
Hello!
kp_digi wrote:I'm new to using TeeChart so please excuse me if this is an obvious question. I would like to export 3 line charts all to a single page .pdf. I'm able to export 3 charts to 3 separate pages withing the .pdf file but how can I get all 3 charts to display on a single page?
No problem. It is not possible to use TeeChart PDF exportation to obtain multiple charts on a single PDF file, however, as an alternative one can print multiple charts to a single page, so opening the possibility of printing to a PDF file. There is an example of how to print multiple charts to a single page in the Tutorials under:
%Program Files%\Steema Software\Steema TeeChart for .NET 2014 4.1.2014.02240\Docs\TeeChart for .Net Tutorials.chm
look in "Tutorial 14 - Printing Charts".
nbp
Post by nbp » Thu Sep 11, 2014 8:58 pm
Is this documentation (Chapter 14 Printing) available online? I recently upgraded to Windows 7 from XP, so have to resintall TChart7. When I did that, I didn't see the help or the documenation anywhere.
Post by Narcís » Fri Sep 12, 2014 11:13 am
No, it's not available on-line. It is included with the TeeChart installation at the location Christopher Ireland mentioned:
Christopher wrote:There is an example of how to print multiple charts to a single page in the Tutorials under:
Do you have this location (or similar) on your machine? It should basically be under the Docs folder in your TeeChart installation. Also, TeeChart version are you using? If you have problems finding the tutorials in your version we can help you.
nbp
Post by nbp » Fri Sep 12, 2014 8:55 pm
Thanks. I downloaded TChart Pro ActiveX v7 and have installed. I have the tutorials now.
nbp
Post by nbp » Thu Feb 23, 2017 9:05 pm
Has this feature been added in a recent release, i.e TChart 2015 or 2016? Or do we still need to use the method described above with the PrintPreviewer?
Post by Christopher » Fri Feb 24, 2017 11:51 am
nbp wrote:Has this feature been added in a recent release, i.e TChart 2015 or 2016? Or do we still need to use the method described above with the PrintPreviewer?
The method described is still the recommended technique for printing multiple charts to a single PDF file.
