Hello steema!
I have terrible performance problems with the latest version of WPF TChart if I use SubChart.
Try to execute the following code and resize window with TChart to reproduce that:
SubChartTool subChartTool = new SubChartTool();
MyTChart.Tools.Add(subChartTool);
TChart subChart = subChartTool.Charts.AddChart(string.Empty);
TChart must be resizable.
It seems that TChart.OnRender is called recursively.
It's awful bug, fix it ASAP please.
WPF. SubChart. Performance problems.
Re: WPF. SubChart. Performance problems.
Hello neurosoft,
I am afraid I can't reproduce the problem here. Could you please send us a simple code where we can reproduce the problem here?
Thanks in advance,
Thanks in advance,
Ok. I've attached a simple example where the problem appears. Just add to the project a reference to the latest version of TeeChart.WPF, run application and press the button 'button'. Then application works very slowly and processor is busy too much.
- WpfApplication1.zip
- (76.35 KiB) Downloaded 557 times
Hello neurosoft,
Many thanks for your project. I have reproduced the problem here. We've added the problem in TeeChart.Net bugzilla tracker to fix it to upcoming versions of TeeChartVCL. Here http://bugs.teechart.net/show_bug.cgi?id=892
you have the link to the ticket.
Remember add your email account to the ticket so you can be automatically notified when and update arrives.
Thanks in advance,
Thanks in advance,
