Font issue in Rectangle tool
amol
Post by amol » Sat Nov 15, 2014 9:20 am
Hi Steema Support,
I am using rectangle tool in my application for showing data and using font "Consolas".With this font data plotted(shown) with proper alignment . But when we use font type "Times New Roman" it changes the alignment of the data and it is shown unmanaged in Rectangle tool.
Is there any way to set the proper alignment using "Times New Roman" font. Please find the attched application to see the changes in alignment.
Please provide any solution for the same asap.
Thanks in advance
Thanks & Regards
PlanoResearch
RectangleToolDemo.rar
Rectangle tool demo
(34.11 KiB) Downloaded 618 times
Re: Font issue in Rectangle tool
Post by Christopher » Mon Nov 17, 2014 11:38 am
As this video shows, the behaviour in this case is expected.
Do you get the same results as in the video above? Which version are you using?
amol
Post by amol » Wed Nov 19, 2014 10:52 am
Hi Steema Support,
Thanks for your reply.
Yes, we got the same result as shown in the vedio.I am using Teechart version 4.1.2011.4191.
Please suggest any solution.
Thanks&Regards
PlanoResearch
Post by Christopher » Wed Nov 19, 2014 10:56 am
amol wrote: Yes, we got the same result as shown in the vedio.I am using Teechart version 4.1.2011.4191.
As I said, this is expected behaviour - I do not see what the problem is, therefore, I cannot suggest a solution.
Can you please tell me the behaviour you would like to see that is different to the default behaviour?
amol
Post by amol » Wed Nov 19, 2014 11:36 am
Hi Christoper,
As shown in video that is previously given by you. In this video it is clearly shown when we press button "Change Font to Times New Roman" then data inside the rectangle tool shows unmanaged this is the issue that we do not want. And when we press button"Change Font to Consolas" then rectangle tool data shows managed or with proper alignment. It look good.
So we want to manage the rectangle tool data alignment with "Times New Roman" also.
Hoping it will help you to clarify the issue.
Please provide any solution for the same.
Thanks&Regards
PlanoResearch
Post by Christopher » Wed Nov 19, 2014 2:26 pm
amol wrote: Hoping it will help you to clarify the issue.
Try using a standard System.Windows.Forms.TextBox to compare behaviour, e.g.
namespace WindowsFormsApplication1
        Points point;
        public RectangleTool rect;
        TextBox textBox;
            point = new Points(tChart1.Chart);
            point.FillSampleValues(30);
            rect = new RectangleTool(tChart1.Chart);
            rect.Top = 100;
            rect.Left = 200;
            rect.Active = true;
            rect.Shape.Font.Name = "Consolas";
            rect.AutoSize = true;
            List<string> lstResultName = new List<string>();
            lstResultName.Add("First Element");
            lstResultName.Add("Second Element");
            lstResultName.Add("Third Element");
            lstResultName.Add("Fourth Element");
            List<string> lstResultUnit = new List<string>();
            lstResultUnit.Add("aaa");
            lstResultUnit.Add("bbbbrer");
            lstResultUnit.Add("cc");
            lstResultUnit.Add("dddd");
            List<string> lstResultValue = new List<string>();
            lstResultValue.Add("29111");
            lstResultValue.Add("2221");
            lstResultValue.Add("12123233");
            lstResultValue.Add("3333434");
            SetResults(lstResultName,lstResultUnit,lstResultValue);
            textBox = new TextBox();
            textBox.Multiline = true;
            textBox.Width = 300;
            textBox.Height = 100;
            tChart1.Controls.Add(textBox);
            textBox.Text = rect.Text;
        public void SetResults(List<string> lstResultName, List<string> lstResultUnit, List<string> lstResultValue)
           string strResults = string.Empty;
            int max = 0;
            int index1 = 0;
            int total = 0;
            for (int i = 0; i < lstResultName.Count; i++)
                if (lstResultUnit[i] != string.Empty)
                    if (max < lstResultName[i].Length + lstResultUnit[i].Length)
                        max = lstResultName[i].Length + lstResultUnit[i].Length;
                    total = lstResultName[i].Length + lstResultUnit[i].Length;
                    if (max == total)
                        string str = lstResultName[i];
                        str = str + "   ";
                        lstResultName[i] = str;
                        for (int j = 0; j < max - (total); j++)
                            str = str + " ";
                        str = str + "   ";
            for (int i = 0; i < lstResultUnit.Count; i++)
                    string str = lstResultUnit[i];
                    str = "[" + str + "] " + "=" + " ";
                    lstResultUnit[i] = str;
                    strResults = strResults + lstResultName[i] + lstResultUnit[i] + lstResultValue[i] + "\r\n";
                    index1++;
            if (index1 == 0)
                rect.Active = false;
            rect.Text = strResults;
            rect.Shape.Font.Name = "Times New Roman";
            textBox.Font = new Font(rect.Shape.Font.Name, 8);
Here, exactly the same thing happens ... the spacing is different when the font changes. Therefore I don't see this as a specific TeeChart issue, but as a generic issue related to the behaviour of different fonts and spaces in the .NET framework.
