I want to add the data to the contour series when I click the button ,but it doesn't disappear. When I copy the same code in the Form_Load function ,it works well . Is there any thing I should to do? The attachment is my appliaction. Thanks!
add data to the contour when I click the button
- WindowsFormsApplication1.rar
- (34.02 KiB) Downloaded 677 times
- Guru
Re: add data to the contour when I click the button
Yes, there seems to be a small problem with the Contour series here, however, it will work if you do:
before filling the series in the button click event.
contour1.Clear();
contour1.Dispose();
contour1 = new Steema.TeeChart.Styles.Contour(tChart1.Chart);
