Drawline Tool Features
Posted: Wed May 20, 2015 6:01 am
by 16071129
Dear Steema,
First of all thank you for adding new styles (e.g.Ellipses,Rectangles) in Drawline tool. I am surprised that Triangle is still not included in this tool. It will help us alot if you add Triangle. I will be glad if you add more features to parallel lines like number of line property. For example if i set no. of line to 3 then while drawing it will draw 3 equidistance parallel lines. This is called as Cycle Lines in Financial Charts. I am adding sample image for your referance.
Re: Drawline Tool Features
Posted: Wed May 20, 2015 10:11 am
by Christopher
I have added to new enhancements to our database to reflect these requests, one with id=1216 and the other with id=1217.
Please be aware that all Steema clients, such as yourself, are warmly invited to subscribe to the Steema database at bugs.steema.net and to add in all suggestions for improvement they deem desirable.
Posted: Tue Jun 02, 2015 4:23 pm
by Christopher
Christopher wrote: the other with id=1217
We have created a new tool called CycleLines which you can test in an Eval assembly of TeeChart.dll you can download from here.
To use this tool, try code such as:
    Candle candle = new Candle();
    CycleLines cycle = new CycleLines();
      tChart1.Series.Add(candle).FillSampleValues(200);
      tChart1.Tools.Add(cycle);
      cycle.LineNumber = 3;
and then use the mouse to draw a line on the chart to and from the required chart areas.
Is this what you had in mind?
Posted: Thu Jun 04, 2015 6:41 am
by 16071129
Dear Christopher,
I am very very thankful that you helped us by creating this major finantial tool. This divides my chart area in equal parts. the LineNumber property of this tool is not working properly as i set LineNumber 2 then it draws 6 lines. Is there any other use of this LineNumber property ? After drawing lines we also require feature to drag and increase spacing between lines. This line spacing must be increase by property also e.g. LineSpacing which can be set programatically. So i can set spacing in Number of days.
Posted: Mon Jun 08, 2015 3:43 pm
by Christopher
I've done a little more work on this which you can download from here.
You can now add and modify lines at runtime, e.g.
    CycleLines lines = new CycleLines();
      tChart1.Tools.Add(lines);
      lines.LineNumber = 3;
    private void button4_Click_1(object sender, EventArgs e)
      DrawLineItem l = new DrawLineItem(lines);
      l.StartPos = new PointDouble(candle.DateValues[50], candle.OpenValues[50]);
      l.EndPos = new PointDouble(candle.DateValues[100], candle.OpenValues[100]);
      lines.Invalidate();
    private void button7_Click_1(object sender, EventArgs e)
      lines.LineSpacing = 20;
Also you can change the distance between the lines by pressing the Control key and dragging them.
Posted: Tue Jun 09, 2015 5:18 am
by 16071129
i used the last evalution u posted. I found some problems while using the tool. Listing them below.
1) line must be selected when clicked on any particular line of cyclelines. (selected line not getting highlighted.)
2) user can click and drag any line to increase distance. (only dragging on first line worked ok.)
3) all lines of cycleline group must always remain equidistant. (when i clicked on second line and dragged to increase distance. it messed up)
Posted: Tue Jun 09, 2015 4:28 pm
by Christopher
Quant wrote:i used the last evalution u posted. I found some problems while using the tool. Listing them below.
Okay, thank you, how about this one here?
Posted: Fri Jun 12, 2015 4:58 am
by 16071129
Dear steema,
i am waiting for this feature in release version. kindly infom me till when i will get it.
Posted: Fri Jun 12, 2015 8:13 am
by Christopher
The last maintenance release was released on 14/05/2015, meaning that the next one is planned for the end of July or beginning of August.
Posted: Thu Sep 24, 2015 12:47 pm
by 16071129
we want fibonacci property in cycleline tool.
which will place lines on fibbonacci distance.
i.e. 0, 1, 1, 2, 3, 5, 8, 13, 21, 34,....
e.g.
http://stockcharts.com/school/doku.php? ... time_zones
Posted: Thu Sep 24, 2015 1:37 pm
by Christopher
Quant wrote:we want fibonacci property in cycleline tool.
This has been added to our ticket database with id=1321 and will be considered for inclusion into our next maintenance release, due out in the middle of November.
Posted: Sat Sep 26, 2015 4:32 am
by 16071129
we want this on urgent basis. can you please help me in it.
Posted: Mon Sep 28, 2015 7:45 am
by Christopher
Quant wrote:we want this on urgent basis. can you please help me in it.
Other than logging your request for a new feature into our online issue tracking system for it to be implemented at a future date, I'm afraid I'm not sure how I can help you further here.
