Rotate does not work with Legend Checkboxes
Posted: Mon Aug 29, 2016 6:35 am
by 15677089
Points points = new Points();
points.Add(10);
MyTChart.Series.Add(points);
var rotate = new Rotate();
MyTChart.Tools.Add(rotate);
MyTChart.Legend.CheckBoxes = true;
I am trying to apply rotate with legend checkboxes.
When rotate is not implemented, legend checkboxes work fine.
But when rotate is implemented, legend checkboxes never work fine.
It seems that it has been posted on wpf forum, too.
URL is
http://www.teechart.net/support/viewtop ... =4&t=14057.
It would be great if you let me know as soon as possible about this issue.
Re: Rotate does not work with Legend Checkboxes
Posted: Mon Aug 29, 2016 2:14 pm
by Christopher
This is now ticket
id=1612, which you can see has now been fixed. The fix for this issue is a one-liner, and if you have the source-code version of TeeChart I can tell you where it is.
Posted: Tue Aug 30, 2016 2:09 am
by 15677089
You mean that it has been fixed with a new dll? I have installed a package on my computer though..
Posted: Tue Aug 30, 2016 2:10 am
by 15677089
Christopher wrote:Hello,
This is now ticket
I thought this might be fixed by changing dll file, but it seems like there is another way to do it?
Posted: Tue Aug 30, 2016 2:42 am
by 15677089
I think that it would be great if a modified dll is released for this issue as this issue is clearly a bug.
Posted: Tue Aug 30, 2016 8:32 am
by Christopher
DEV1 wrote:I think that it would be great if a modified dll is released for this issue as this issue is clearly a bug.
Yes, a new maintenance release for TeeChart.NET is expected to be released in the first half of September.
Posted: Wed Aug 31, 2016 12:39 am
by 15677089
In case it gets delayed, I would like to know what I need to change for the source code.
Posted: Wed Aug 31, 2016 7:57 am
by Christopher
DEV1 wrote:In case it gets delayed, I would like to know what I need to change for the source code.
Of course - the change is here:
- id1612.PNG (10.83 KiB) Viewed 18718 times
Posted: Thu Jan 26, 2017 5:40 am
by 15677090
Is this issue fixed yet? I want to know if this issue has been fixed.
Posted: Thu Jan 26, 2017 12:12 pm
by Christopher
PidoTech wrote:Is this issue fixed yet? I want to know if this issue has been fixed.
Yes, that change is in the last publicly available release - ID1612
here.
