ClickSeries Event don't work in Funnel and pyramid styles
digihail
Post by digihail » Fri Dec 09, 2016 2:31 am
I need to use Clickseries Event in Funnel and pyramid style,but it don't tigger at all. I have checked in source,I found those styles have no implementation click(int x, int y) function which should override in each childern style.So I should how to achieve it.
Re: ClickSeries Event don't work in Funnel and pyramid styles
Post by Christopher » Fri Dec 09, 2016 11:19 am
digihail wrote:I need to use Clickseries Event in Funnel and pyramid style,but it don't tigger at all. I have checked in source,I found those styles have no implementation click(int x, int y) function which should override in each childern style.So I should how to achieve it.
Apologies for these inconveniences - I have been able to reproduce these issues here and have added them to our issue tracker with ticket numbers id=1714 and id=1715.
digihail
Post by digihail » Fri Dec 23, 2016 8:17 am
I have this problem in the source code to repair in pyramid styles.
Post by Christopher » Fri Dec 23, 2016 3:36 pm
digihail wrote:I have this problem in the source code to repair in pyramid styles.
Could you please give me your email and I can then send the changes to you?
