Set initial values for ScrollPager where?
biqpaulson
Post by biqpaulson » Thu Mar 02, 2017 9:03 pm
I have been trying to put up the ScrollPager tool, get the user input, close the ScrollPager, add again the ScrollPager but have it set to what it was set to previously.
I cannot find the values to set in order to position the ColorBandTool in the previous location.
Here is the small piece of code that I have been using in order to try this out.
In the designer add one chart and one button:
using Steema.TeeChart;
using Steema.TeeChart.Styles;
using Steema.TeeChart.Tools;
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Diagnostics;
namespace ScrollPagerTest
            InitializeChart();
        ScrollPager tool;
        Steema.TeeChart.Styles.Line series;
            tChart1.Header.Text = "Scroll Pager Tool";
            tChart1.Series.Add(series = new Steema.TeeChart.Styles.Line());
            series.FillSampleValues(1000);
            series.Legend.Visible = false;
        private void AddPagerTool()
            if (tool != null)
                Debug.Print("StartValue before destruction = " + tool.StartValue);
                Debug.Print("EndValue before destruction = " + tool.EndValue);
            Debug.Print("MinimumValue before adding PagerTool = " + tChart1.Axes.Bottom.Minimum);
            Debug.Print("MaximumValue before adding PagerTool = " + tChart1.Axes.Bottom.Maximum);
            tChart1.Tools.Clear();
            double StartValue = tChart1.Axes.Bottom.Minimum;
            double EndValue = tChart1.Axes.Bottom.Maximum;
            tChart1.Tools.Add(tool = new ScrollPager());
            tool.Series = series;
            tool.SubChartTChart.Panel.Pen.Visible = false;
            tool.SubChartTChart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
            tool.SubChartTChart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
            Debug.Print("StartValue after creation = " + tool.StartValue);
            Debug.Print("EndValue after creation = " + tool.EndValue);
            tool.StartValue = StartValue;
            tool.EndValue = EndValue;
#if false
            tool.ColorBandTool.Start = StartValue;
            tool.ColorBandTool.End = EndValue;
            tool.GetHorizAxis.Minimum = StartValue;
            tool.GetHorizAxis.Maximum = EndValue;
#endif
            Debug.Print("StartValue after setting from value originally in chart = " + tool.StartValue);
            Debug.Print("EndValue after setting from value originally in chart = " + tool.EndValue);
            AddPagerTool();
So, how do I do this?
Re: Set initial values for ScrollPager where?
Post by Christopher » Fri Mar 03, 2017 9:49 am
biqpaulson wrote: So, how do I do this?
You can do this by calling the tChart1.Draw() method which will initialize all chart value, some of which depend on the Chart being completely rendered. The following code works as expected here:
			if (tool != null)
			tChart1.Draw(); //Draw the chart to initialize all values
#if false
#endif
biqpaulson
Post by biqpaulson » Fri Mar 03, 2017 1:34 pm
Works great! Thanks!
biqpaulson
Post by biqpaulson » Sat Mar 04, 2017 3:02 am
I think i spoke too soon.
If I use a Sphere style and a Points series the line you gave me crashes.
//#define USE_POINTER_STYLE_SPHERE
using System;
using System.Data;
using System.Linq;
using System.Text;
            InitializeChart();
        ScrollPager tool;
        Steema.TeeChart.Styles.Points series;
            tChart1.Series.Add(series = new Steema.TeeChart.Styles.Points());
            series.FillSampleValues(100);
#if (USE_POINTER_STYLE_SPHERE)
            series.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Sphere;
#endif
            if ((StartValue != tChart1.Axes.Bottom.MinXValue)
                (EndValue != tChart1.Axes.Bottom.MaxXValue))
            AddPagerTool();
Run the code above and it works.
Uncomment out the:
So it is:
Run and push the button on the form.
It will crash in tChart1.Draw();
with the exception:
ex.Message = "Object reference not set to an instance of an object."
And a stack trace of:
   at Steema.TeeChart.Drawing.Graphics3D.MixClip(Region region)
   at Steema.TeeChart.Drawing.Graphics3D.SphereEnh(Int32 x1, Int32 y1, Int32 x2, Int32 y2)
   at Steema.TeeChart.Styles.SeriesPointer.Draw(Graphics3D g, Boolean is3D, Int32 px, Int32 py, Int32 tmpHoriz, Int32 tmpVert, Color colorValue, PointerStyles aStyle)
   at Steema.TeeChart.Styles.SeriesPointer.Draw(Graphics3D g, Int32 px, Int32 py, Color colorValue, PointerStyles aStyle)
   at Steema.TeeChart.Styles.CustomPoint.DrawPointer(Int32 aX, Int32 aY, Color aColor, Int32 valueIndex)
   at Steema.TeeChart.Styles.CustomPoint.DrawValue(Int32 valueIndex)
   at Steema.TeeChart.Styles.Series.DoDrawIndex(Int32 Index, Boolean CanID)
   at Steema.TeeChart.Styles.Series.Draw()
   at Steema.TeeChart.Styles.Series.DrawSeries()
   at Steema.TeeChart.Chart.DoDraw(Graphics3D g, Int32 First, Int32 Last, Int32 Inc)
   at Steema.TeeChart.Chart.DrawAllSeries(Graphics3D g)
   at Steema.TeeChart.Chart.InternalDraw(Graphics g, Boolean noTools)
   at Steema.TeeChart.Chart.Draw(Graphics g, Rectangle r, Boolean noTools)
   at Steema.TeeChart.Chart.Draw(Graphics g, Rectangle r)
   at Steema.TeeChart.Chart.Draw()
   at ScrollPagerTest.Form1.AddPagerTool() in C:\Users\Gary\Documents\Visual Studio 2015\Projects\ScrollPagerTest\ScrollPagerTest\Form1.cs:line 118
Post by Christopher » Mon Mar 06, 2017 10:12 am
biqpaulson wrote: If I use a Sphere style and a Points series the line you gave me crashes.
I have been able to confirm this unhandled exception and have already fixed it. Many apologies for the inconvenience. In the meantime you can use the following code to workaround the issue:
    ScrollPager tool;
      double StartValue = 5;
      double EndValue = 25;
      series.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
      tool.SubChartTChart.Series.RemoveAllSeries();
      AddPagerTool();
