Page 2 of 2
Re: Line plotting issue
Posted: Wed May 10, 2017 9:34 am
by Christopher
Hello Siva,
Having spoken to my colleagues, they inform me that you have a valid license (from November) which will enable you to use the latest version of the source-code. My suggestion is that you use this latest version and apply the patch I have indicated to it. I hope that helps.
Posted: Fri May 12, 2017 6:55 am
by 16079464
Hey Chris,
Currently we are in final stages of release. It's difficult to upgrade to latest version now as it will require additional testing.
Can you check whether you can provide fix for the version I had mentioned? If possible please provide a timeline for when you can provide fix.
Siva
Posted: Fri May 12, 2017 8:00 am
by Christopher
Hello Siva,
Siva wrote: Can you check whether you can provide fix for the version I had mentioned? If possible please provide a timeline for when you can provide fix.
That should be perfectly possible. Could you please get in touch with sales@steema.com and they will be happy to provide you with a quote and a timeline for the fix.
Posted: Fri May 12, 2017 8:38 am
by 16079464
Hey Chris,
Just to be clear I'm not asking when newer version comes out with this fix. I'm asking whether fix can be provided for older version ( .NET v2012 - 4.1.2012.1311). If yes how much time is required for this fix?
Siva
Posted: Fri May 12, 2017 8:55 am
by Christopher
Hello Siva,
Understood. We at Steema are willing to provide a fix for an older version of the TeeChart.NET source code - all you need to do is to write to sales@steema.com and we will provide you with a quote for the work. If you are happy with the quote and timeline we provide then I can get on and do it for you.
