Individual styling of labels in axis
Calzone
Post by Calzone » Thu Apr 27, 2017 12:34 pm
Is there a way to make some of the labels in the y-axis bold/larger font? (To create group headers.)
Using TChart android in xamarin.
Calzone
Re: Individual styling of labels in axis
Post by Calzone » Thu Apr 27, 2017 12:44 pm
Edit: using gantt chart
Post by Sandra » Fri Apr 28, 2017 4:43 pm
Hello Calzone,
The code below shows you how can change each axis label:
        tChart1.Axes.Left.Labels.Items[0].Font.Bold = true;
        tChart1.Axes.Left.Labels.Items[1].Font.Size = 15;
Hoping this helps you, otherwise don't hesitate to contact us.
Thanks in advances
Calzone
Post by Calzone » Tue May 02, 2017 8:18 am
Hi
Thanks for the reply.
In my app the "chart.Axes.Left.Labels.Items.count" is 0. ( after chart.Series.Add(gantt);)
I do not explicitly add any labels, Its labels from "gantt.Add(pkt.FromDate, pkt.ToDate, pkt.Order, pkt.Name);" I wish to highlight based om some property.
Post by Sandra » Tue May 02, 2017 11:51 am
Hello Calzone,
Sorry, I didn't inform you that is necessary use CustomLabels to get the result you expected. I have modified the above code to do as you want.
            InitializeChart();
            Steema.TeeChart.Styles.Gantt gantt = new Steema.TeeChart.Styles.Gantt(tChart1.Chart);
            gantt.FillSampleValues(10);
            tChart1.Axes.Left.Labels.Items.Clear();
            for (int i=0; i<gantt.Count; i++)
                tChart1.Axes.Left.Labels.Items.Add(gantt.YValues[i], gantt.Labels[i]);
                if (i%2==0)
                    tChart1.Axes.Left.Labels.Items[i].Font.Bold = true;
                    tChart1.Axes.Left.Labels.Items[i].Font.Size = 12;
Could you tell us if it now works in your end?
Hoping this helps you.
Thanks in advance
