Save chart to memory stream ver, 4.1.2015.12163
imd-soft
Post by imd-soft » Thu May 04, 2017 8:18 am
Hi.
We have an error in the TeeChart.WPF.dll (Height must be non-negative) in our project
when we are trying save the chart to memory stream.
Can you help with it?
Re: Save chart to memory stream ver, 4.1.2015.12163
Post by Christopher » Thu May 04, 2017 9:54 am
the following code works as expected:
  public partial class MainWindow : Window
    public MainWindow()
      CreateChart();
      InitializeChart();
    TChart tChart1, tChart2;
      line.FillSampleValues();
    private void CreateChart()
      tChart1 = new TChart();
      tChart1.Margin = new Thickness(0);
      tChart1.Height = 200;
      dockPanel.Children.Add(tChart1);
      tChart2 = new TChart();
      tChart2.Margin = new Thickness(0);
      tChart2.Height = 200;
      dockPanel.Children.Add(tChart2);
    private void Button_Click(object sender, RoutedEventArgs e)
      MemoryStream stream = new MemoryStream();
      tChart1.Export.Template.Save(stream);
      stream.Position = 0;
      tChart2.Import.Template.Load(stream);
could you please modify the above code so I can reproduce your issue here?
imd-soft
Post by imd-soft » Thu May 04, 2017 10:27 am
I am sending the code with an error.
MainWindow.xaml
<Window x:Class="TeeChart.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006 ... esentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/marku ... ility/2006"
xmlns:local="clr-namespace:TeeChart"
xmlns:wpf="clr-namespace:Steema.TeeChart.WPF;assembly=TeeChart.WPF"
mc:Ignorable="d"
Title="MainWindow" Height="500" Width="800">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="*"/>
<RowDefinition Height="Auto"/>
</Grid.RowDefinitions>
<wpf:TChart Name="tChart" Grid.Row="0"/>
<StackPanel Orientation="Horizontal" Grid.Row="1" HorizontalAlignment="Center">
<Button x:Name="BtnGetImage" Click="BtnGetImage_OnClick" Margin="5">Save chart to memory stream</Button>
</StackPanel>
</Grid>
</Window>
MainWindow.xaml.cs
public MainWindow()
this.Loaded += MainWindow_Loaded;
private void MainWindow_Loaded(object sender, RoutedEventArgs e)
tChart.Series.Clear();
tChart.Axes.Custom.Clear();
tChart.Width = 731;
tChart.Height = 448;
tChart.Axes.Bottom.SetMinMax(0, 12);
AddFirstTwoSeries();
var mySeries = SetMySeries();
SetDataMySeries(mySeries);
AddCustomAxes(mySeries);
private void AddCustomAxes(Series mySeries)
Steema.TeeChart.WPF.Axis newAxis = new Steema.TeeChart.WPF.Axis();
newAxis.Horizontal = false;
Steema.TeeChart.WPF.Axis customAxis = tChart.Axes.Custom.Add(newAxis);
mySeries.CustomVertAxis = customAxis;
var customAxisId = tChart.Axes.Custom.IndexOf(customAxis);
var myCustomAxis = tChart.Axes.Custom[customAxisId];
myCustomAxis.Visible = true;
myCustomAxis.AxisPen.Color = mySeries.Color;
myCustomAxis.MinorGrid.Visible = false;
myCustomAxis.Labels.Font.Color = mySeries.Color;
myCustomAxis.Labels.Font.Bold = false; //True
myCustomAxis.Ticks.Visible = false;
myCustomAxis.MinorTicks.Visible = false;
myCustomAxis.Grid.Visible = false;
myCustomAxis.AxisPen.Visible = false;
myCustomAxis.Increment = 1;
myCustomAxis.Labels.ValueFormat = "###0.###";
myCustomAxis.Automatic = false;
myCustomAxis.Maximum = (double) 10;
myCustomAxis.Minimum = (double) 0;
myCustomAxis.PositionUnits = Steema.TeeChart.WPF.PositionUnits.Percent;
myCustomAxis.RelativePosition = 0;
private static void SetDataMySeries(Series mySeries)
mySeries.Title = "Di";
mySeries.Legend.Visible = true;
mySeries.Add(2, (double)2, " 1", Colors.Blue);
mySeries.Add(3, (double)12, " 2", Colors.Blue);
private Series SetMySeries()
Steema.TeeChart.WPF.Styles.Series series3 = tChart.Series.Add(new Steema.TeeChart.WPF.Styles.Line(tChart.Chart));
var seriesIndex = tChart.Series.IndexOf(series3);
var mySeries = tChart.Series[seriesIndex];
((Steema.TeeChart.WPF.Styles.Line) mySeries).Pointer.Style =
(Steema.TeeChart.WPF.Styles.PointerStyles) 0;
((Steema.TeeChart.WPF.Styles.Line) mySeries).Pointer.Visible = true;
((Steema.TeeChart.WPF.Styles.Line) mySeries).LinePen.Visible = false;
return mySeries;
private void AddFirstTwoSeries()
tChart.Series[0].VertAxis = Steema.TeeChart.WPF.Styles.VerticalAxis.Left;
tChart.Series[0].Legend.Visible = false;
tChart.Series[1].VertAxis = Steema.TeeChart.WPF.Styles.VerticalAxis.Right;
tChart.Series[1].Legend.Visible = false;
private void BtnGetImage_OnClick(object sender, RoutedEventArgs e)
var xamlFormat = new XAMLFormat(tChart.Chart);
using (MemoryStream ms = new MemoryStream())
try
xamlFormat.Save(ms);
MessageBox.Show("Ok", "Saving chart to memory stream");
catch (Exception ex)
Console.WriteLine(ex);
MessageBox.Show($" {ex.Message}", "Error when saving chart to memory stream ");
Post by Christopher » Thu May 04, 2017 2:56 pm
Thank you. I have been able to reproduce this error and have added it to our issue-tracking software with id=1857. As you can see, this issue has now been fixed.
A workaround is to make sure that there are no points outside of the minimum and maximum axes ranges when exporting to XAML. In your code example you could do this by adding in a loop to delete the points outside of the maximum left axis range in the AddCustomAxes method, e.g.
      myCustomAxis.Maximum = (double)10;
      myCustomAxis.Minimum = (double)0;
      for (int i = 0; i < mySeries.Count; i++)
        if(mySeries.YValues[i] > myCustomAxis.Maximum)
          mySeries.Delete(i);
