Hello!
Sometimes right border in histogram series are not drawing correctly. Please try attached sample: left and top borders of the bars are Ok, but right borders are absent. If you comment line "series.UseYOrigin = true" right border will appear. Or you can move histogram up via right mouse button - right border will also appear.
I am using TChart version 4.1.2017.03140.
Histogram drawing bug
- TChartTest.zip
- (29.2 KiB) Downloaded 629 times
- Guru
Re: Histogram drawing bug
Thank you for reporting this one, I have added it to our issue tracker with id=1872 and a fix to it will be considered for inclusion into the next maintenance release. In the meantime the workaround is to ensure that the value for YOrigin (in the case that UseYOrigin = true) is greater than the Y/left axis, e.g.
public MainWindow()
MyTChart.Width = 400;
MyTChart.Height = 300;
MyTChart.Aspect.UseGuidelines = true;
MyTChart.Axes.Left.AutomaticMinimum = false;
int min = 1;
MyTChart.Axes.Left.Minimum = min;
series = new Histogram();
series.UseYOrigin = false;
series.YOrigin = min;
series.Add(0);
series.Add(10);
series.Add(0);
series.Add(10);
series.Add(0);
MyTChart.Series.Add(series);
public Histogram series;
