Preventing tooltip data from being added to the axis
Jens Ramlow
Post by Jens Ramlow » Tue Oct 17, 2017 9:14 am
Hello Steema team,
I'm using Steema's TeeChart.WPF.
The chart I'm implementing contains three Series from TeeChart.WPF.Styles.Line and TeeChart.WPF.Styles.Points.
For the points I make use of adding tooltip information by using
C#
Steema.TeeChart.WPF.Tools.MarksTip MarksTip_Points_Values = new Steema.TeeChart.WPF.Tools.MarksTip(MainChart.Chart)
   Series = ChartPoints_Values
I'm adding values to the serie by using the overloaded function
C#
ChartPoints_Values.Add((int) viewRowStation.Row["ID"], (double) viewRowValues.Row["Value"], string.Format("Tooltip information... {0}: {1} | {2}", value, value, value), PointColor);
where you may see the tooltip information is a more or less complex tupel.
But whenever a point is added, the tooltip text will be shown on the corresponding X-axis.
(see picture where "Station 9" is getting overlayed from information)
overlay on the X-Axis with information from tooltip
How can I prevent the tooltips from being shown on an axis?
Additional curiosity I cannot resolve is seen in the two more pictures, attached.
Zoomed into the (same) chart - there are no tooltip information over the axis labels.
The same chart moved a bit to the right with panning, so the third point comes into the visible chart area - voilá tooltip information over the axis label.
Thank you.
Best, Jens
zoomed into the chart - panned to the right: tooltip information arise
one point more - with tooltips.PNG (20.54 KiB) Viewed 7687 times
zoomed into the chart - no tooltip information over
zoomed - no tooltips.PNG (5.74 KiB) Viewed 7682 times
Re: Preventing tooltip data from being added to the axis
Post by Christopher » Tue Oct 17, 2017 3:11 pm
Hello Jens,
I'm having difficulty reproducing this one here (in a straight WPF app). I'm trying to do so with code such as the following:
    Points series;
    Random rnd = new Random();
      series = new Points(tChart1.Chart);
      for (int i = 0; i < 10; i++)
        double val = rnd.Next(0, 500);
        series.Add(i, val, i.ToString());
        //series.Add(i, val);
      MarksTip tool = new MarksTip(tChart1.Chart);
      tool.Style = MarksStyles.LabelValue;
      tool.Series = series;
      tChart1.Panel.MarginBottom = 20;
      tChart1.MouseMove += TChart1_MouseMove;
    private double oldY = -1;
    private void TChart1_MouseMove(object sender, MouseEventArgs e)
      int index = series.Clicked(e.GetPosition(tChart1));
      if(index > -1)
        double x = series.XValues[index];
        double y = series.YValues[index];
        if(oldY != y)
          series.Add(x, y, "this is a label");
          oldY = y;
however, using neither of the series.Add() lines can I reproduce your problem (in this case adding in new points when mouse-overing old ones). Could you please modify the above code in some way so I can reproduce your problem here?
Jens Ramlow
Post by Jens Ramlow » Wed Oct 18, 2017 7:55 am
Hello Christopher,
Thank you for diving into the problem.
Occasionally, since implementing your hint from topic "Displaying every label on X-Axis" the effect is not longer available.
foreach (DataRowView viewRowStation in viewStationTable)
//Create labels for stations on X_Axis
   Steema.TeeChart.WPF.AxisLabelItem item = MainChart.Axes.Bottom.Labels.Items.Add((int) viewRowStation.Row["StationID"], (string) viewRowStation.Row["StationName"]);
Probably there were a difficult mix of series, points, marks and lables TeeChart had to calculate for the X-axis labeling. With a manually added set of labels the calculation may freed up from this.
So, no need for further investigation here.
Yours, Jens
