Bar chart - negative values versus bottom axes
Bank Van Breda
Post by Bank Van Breda » Fri May 04, 2018 12:23 pm
How do we compensate for the space needed to show negative bar marks?
Cfr screenshot
Screen Shot 2018-05-04 at 14.17.54.png (50.24 KiB) Viewed 16593 times
The last bar has a negative value and now masks the bottom axes value. Can we fix this with some offset and if yes how do we calculate that margin?
Side question, can we manipulate the position of the bar marks? So that they will always be above the bar instead of following the value and be below the bar for negative values?
Re: Bar chart - negative values versus bottom axes
Post by Christopher » Mon May 07, 2018 8:20 am
Using the latest version of the TeeChart.dll and the following code:
			Bar bar = new Bar(tChart1.Chart);
			bar.Add(3);
			bar.Add(4);
			bar.Add(5);
			bar.Add(-2);
I obtain this:
that is, TeeChart correctly calculates the margin in this default case. Could you please send me a simple code example of the code you're using to obtain the TeeChart in the image you sent? I can then add to this code to show you the options.
Bank Van Breda
Post by Bank Van Breda » Mon May 07, 2018 8:47 am
The demo code for this is giving here : http://www.teechart.net/support/viewtop ... =4&t=16893
If that does not render the same issue, I'll try to extract it from my project...
Post by Sandra » Mon May 07, 2018 2:30 pm
Hello Bank Van Breda,
The problem you're experiencing doesn't appear for us using the code below and latest TeeChart for Xamarin.Forms build 4.2018.4.26.
    ChartView tChart1;
		public MainPage()
			tChart1 = new ChartView();
			tChart1.Chart.Panning.Allow = ScrollModes.None;
			tChart1.Chart.Panel.Gradient.Visible = false;
			tChart1.Chart.Panel.Color = Color.White;
			tChart1.Chart.Walls.Back.Visible = false;
			tChart1.Chart.Header.Visible = false;
			tChart1.Chart.Legend.Visible = false;
			tChart1.Chart.Aspect.View3D = false;
			bar1.Add(7.36);
			bar1.Add(4.027);
			bar1.Add(6.26);
			bar1.Add(7.93);
			bar1.Add(-0.596);
			bar1.Color = Color.Green;
			bar1.Marks.Visible = true;
			bar1.Marks.Transparent = true;
			bar1.Marks.BackColor = Color.Transparent;
			bar1.Marks.Pen.Visible = false;
			bar1.Marks.TailStyle = Steema.TeeChart.Styles.MarksTail.None;
			bar1.Marks.Arrow.Visible = false;
			 bar1.Marks.Font.Size = 14;
			bar1.GetSeriesMark += Bar1_GetSeriesMark;
			tChart1.Chart.Axes.Left.Labels.Style = Steema.TeeChart.AxisLabelStyle.Text;
			tChart1.Chart.Axes.Left.Labels.Font.Size = 14;
			tChart1.Chart.Axes.Left.Ticks.Visible = true;
			tChart1.Chart.Axes.Left.MinorTicks.Visible = true;
			tChart1.Chart.Axes.Left.AxisPen.Visible = true;
			tChart1.Chart.Axes.Left.Grid.Visible = false;
			tChart1.Chart.Axes.Bottom.Grid.Visible = false;
			tChart1.Chart.Axes.Bottom.Labels.Font.Size = 18;
			tChart1.Chart.GetAxisLabel += Chart_GetAxisLabel;
			tChart1.Chart.Panel.MarginLeft = 30;
			tChart1.WidthRequest = 650;
			tChart1.HeightRequest = 350;
			Content = new StackLayout
				Children =
										tChart1
				VerticalOptions = LayoutOptions.CenterAndExpand,
				HorizontalOptions = LayoutOptions.CenterAndExpand,
		private void Chart_GetAxisLabel(object sender, GetAxisLabelEventArgs e)
			if (sender == tChart1.Chart.Axes.Left)
				if (e.ValueIndex != -1)
					e.LabelText = e.Series.YValues[e.ValueIndex].ToString() + "%";
		private void Bar1_GetSeriesMark(Steema.TeeChart.Styles.Series series, Steema.TeeChart.Styles.GetSeriesMarkEventArgs e)
			e.MarkText = "+ " + e.MarkText;
You can show the results I have gotten below:
Could you confirm us you're using latest Teechart for Xamarin.Forms version?
Also, you may be interested in checking out the solutions suggested below to change marks positions:
http://www.teechart.net/support/viewtopic.php?t=5160
http://www.teechart.net/support/viewtopic.php?t=560
Hoping this helps you,
Thanks in advance
Bank Van Breda
Post by Bank Van Breda » Tue May 08, 2018 2:38 pm
A small reply already...
Indeed in a test app with given example code this works fine!
In our production app, not. So I'm trying to rework the example app to see if I can spot the difference. :)
Bank Van Breda
Post by Bank Van Breda » Tue May 08, 2018 3:12 pm
Found it... we manipulate left Max value mark
BarChart.Chart.Axes.Left.MaximumOffset = 5;
BarChart.Chart.Axes.Left.AutomaticMaximum = false;
BarChart.Chart.Axes.Left.Maximum = maxValue;
And that MaximumOffset is not needed!
Sorry, our bad ;)
Post by Sandra » Wed May 09, 2018 12:49 pm
Many thanks for the information. I'm glad you have found where the problem is produced.
Feel free contact us if you have more doubts.
Thanks in advance
