Any reason why the slice center points are not stopping in the center of the pie chart?
The values for the middle one are these by the way
pieData.Data.Add(new GraphData() { Value = 81, Color = Color.FromHex("#B9C4D8") });
pieData.Data.Add(new GraphData() { Value = 1, Color = Color.FromHex("#1D386D") });
pieData.Data.Add(new GraphData() { Value = 10, Color = Color.FromHex("#F5A623") });
pieData.Data.Add(new GraphData() { Value = 5, Color = Color.FromHex("#BBC3D3") });
pieData.Data.Add(new GraphData() { Value = 3, Color = Color.FromHex("#1D386D") });
Pie chart values - off center slices
Bank Van Breda
Re: Pie chart values - off center slices
Hello Bank Van Breda,
I would like inform you that the Pen problems is added in Teechart Xamarin.iOS Bugzilla tracker to review the problem to upcoming maintenance release. Here's the link: http://bugs.teechart.net/show_bug.cgi?id=2033
On the other hand, finally, we have found a good solution, that allow to explode any pie slice. The code below show you how can do it:
Hoping this helps you.
Thanks in advance
public MainPage()
tChart1 = new ChartView();
tChart1.Chart.Panning.Allow = ScrollModes.None;
tChart1.Chart.Panel.Gradient.Visible = false;
tChart1.Chart.Panel.Color = Color.White;
tChart1.Chart.Walls.Back.Visible = false;
tChart1.Chart.Header.Visible = false;
tChart1.Chart.Legend.Visible = false;
tChart1.Chart.Aspect.View3D = false;
Steema.TeeChart.Styles.Pie pie1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
pie1.Add(81, Color.FromHex("#B9C4D8"));
pie1.Add(1, Color.FromHex("#1D386D"));
pie1.Add(10, Color.FromHex("#F5A623"));
pie1.Add(5, Color.FromHex("#BBC3D3"));
pie1.Add(3, Color.FromHex("#BBC3D3"));
pie1.Marks.Visible = false;
pie1.AutoPenColor = false;
pie1.Pen.Visible = false;
pie1.Circled = true;
pie1.ExplodedSlice[0] = 5;
pie1.ExplodedSlice[1] = 10;
pie1.ExplodedSlice[2] = 5;
pie1.ExplodedSlice[3] = 15;
pie1.ExplodedSlice[4] = 5;
tChart1.WidthRequest = 650;
tChart1.HeightRequest = 350;
Content = new StackLayout
Children =
tChart1
VerticalOptions = LayoutOptions.CenterAndExpand,
HorizontalOptions = LayoutOptions.CenterAndExpand,
}Thanks in advance
| Sandra Pazos / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
Bank Van Breda
I guess I'll wait for the bug fix... because setting each slice as exploded with value 5 has following visual effect.
I would like inform you we're working to fix the problem. We contact with you as soon as possible.
Thanks in advance
Thanks in advance
We have published a new TeeChart.Net for Xamarin.Froms maintenance release where the bug id2033 is fixed. You can download it from Client Download page
Thanks in advance
Thanks in advance
Bank Van Breda
Thanks for the great support! Now works as expected
