Radar chart
Posted: Fri May 25, 2018 1:22 pm
by 9526439
Hi Steema Team,
Can you please send an example for Radar chart in c# silverlight.
I am not able to generate it.
I wanted to create a radar chart like below image.
- Radar.png (34.37 KiB) Viewed 23747 times
Re: Radar chart
Posted: Mon May 28, 2018 6:11 am
by 9526439
Please reply us this is very urgent for us.
Re: Radar chart
Posted: Mon May 28, 2018 10:18 am
by Christopher
Hello!
The following code:
public MainPage()
tChart1.Aspect.ClipPoints = false;
Radar series = new Radar(tChart1.Chart);
series.Add(100, "Source");
series.Add(25, "Seal");
series.Add(100, "Closure");
series.Add(50, "Reservoir");
series.Add(90, "Timing");
series.GetVertAxis.SetMinMax(0, 100);
series.CircleLabels = true;
series.Brush.Visible = false;
gives me this:
- sllauncher_2018-05-28_12-17-09.png (68.81 KiB) Viewed 23727 times
Re: Radar chart
Posted: Mon May 28, 2018 2:02 pm
by 9526439
Hi Steema Team,
Thanks for the solution. I need some more help.
I need to show the min and max range for some values. see in below image
- Untitled.png (42.99 KiB) Viewed 23725 times
In this black line cutting the axis is showing min and max for seal and reservoir .
I need same.Please help me in this.
Amol
Re: Radar chart
Posted: Mon May 28, 2018 2:03 pm
by 9526439
How can i show min and max point for any particular value.
Re: Radar chart
Posted: Tue May 29, 2018 1:50 pm
by 9526439
Please reply to my query....
Amol
Re: Radar chart
Posted: Wed May 30, 2018 9:49 am
by Christopher
Hello Amol,
just to remind you that you can use the TeeChart Draw events to draw anything you like on your charts:
- TeeChartNetExamples_2018-05-30_11-46-30.png (180.85 KiB) Viewed 23702 times
so in the case of the Radar series you can do something like this:
- sllauncher_2018-05-30_11-47-37.png (69.05 KiB) Viewed 23702 times
using the following code:
Radar series;
public MainPage()
private void TChart1_AfterDraw(object sender, Steema.TeeChart.Silverlight.Drawing.Graphics3D g)
Point center = new Point(series.CalcXPos(1), series.CalcYPos(1));
Rect rect = Utils.FromLTRB(center.X - 20, center.Y - 10, center.X + 20, center.Y + 10);
g.Pen.Color = Colors.Red;
g.HorizontalLine(rect.Left, rect.Right, center.Y);
g.VerticalLine(rect.Left, rect.Top, rect.Bottom);
g.VerticalLine(rect.Right, rect.Top, rect.Bottom);
Re: Radar chart
Posted: Wed Jun 06, 2018 10:42 am
by 9526439
Hi Steema Team,
I need to draw red marked image but in range using scale of axis and it should correspondent to scale.
For example in below image.
- Untitled.png (72.51 KiB) Viewed 23682 times
Also i need a tool tip to show the data of additional draw image. like in above image.
Amol
Re: Radar chart
Posted: Thu Jun 07, 2018 1:00 pm
by Christopher
Okay, the solution to this one is a little complicated and involves extracting a little of the TChart source-code - but it is possible, as you can see here:
Radar series;
public MainPage()
private void CalcXYPos(double xvalue, double yvalue, double aRadius, Axis axis, out double x, out double y)
double tmp = axis.Maximum - axis.Minimum;
double tmpDif = axis.Inverted ? axis.Maximum - yvalue : yvalue - axis.Minimum;
bool tmpAtEnd = tmpDif < 0;
if ((tmp == 0) || tmpAtEnd)
x = series.CircleXCenter;
y = series.CircleYCenter;
double tmpRadius = tmpDif * aRadius / tmp;
series.AngleToPos((series.ClockWiseLabels ? -Utils.PiStep : Utils.PiStep) * xvalue, tmpRadius, tmpRadius, out x, out y);
Func<Point, Point, Tuple<double, double>> CalculateLine = (first, second) =>
//y − y1 = m(x − x1)
double m = (first.Y - second.Y) / (first.X - second.X);
//y = mx + b
double b = (m * (-1 * second.X)) + second.Y;
return new Tuple<double, double>(m, b);
Func<Tuple<double, double>, Point, Tuple<double, double>> CalculatePerpendicularLine = (aline, apoint) =>
double m = Math.Pow(aline.Item1, -1) * -1;
double b = (m * (-1 * apoint.X)) + apoint.Y;
Func<int, double> GetXValue = (valueIndex) =>
Func<int> GetMaxValuesCount = () =>
int result = 0;
bool FirstTime = true;
foreach (Series s in tChart1.Series)
if (s.Active && (FirstTime || ((s.Count > result) && s.Function == null)))
result = s.Count;
FirstTime = false;
return result;
int tmpIndex = series.ClockWiseLabels ? series.Count - valueIndex : valueIndex;
return (GetMaxValuesCount() > 0) ? tmpIndex * (360.0 / GetMaxValuesCount()) : 0;
int index = 1;
Point center = new Point(series.CalcXPos(index), series.CalcYPos(index));
double plusValue = series.YValues[index] + (series.YValues[index] * 0.45); //45% of value
double minusValue = series.YValues[index] - (series.YValues[index] * 0.22); //22% of value
double x, y;
CalcXYPos(GetXValue(index), plusValue, series.XRadius, series.GetVertAxis, out x, out y);
Point max = new Point(x, y);
CalcXYPos(GetXValue(index), minusValue, series.XRadius, series.GetVertAxis, out x, out y);
Point min = new Point(x, y);
g.Line(center, max);
g.Line(center, min);
Tuple<double, double> line = CalculateLine(min, max);
Tuple<double, double> maxline = CalculatePerpendicularLine(line, max);
Tuple<double, double> minline = CalculatePerpendicularLine(line, min);
//draw whiskers
int offset = 3;
g.Line(max, new Point(max.X + offset, (max.X + offset) * maxline.Item1 + maxline.Item2));
g.Line(max, new Point(max.X - offset, (max.X - offset) * maxline.Item1 + maxline.Item2));
g.Line(min, new Point(min.X + offset, (min.X + offset) * minline.Item1 + minline.Item2));
g.Line(min, new Point(min.X - offset, (min.X - offset) * minline.Item1 + minline.Item2));
- sllauncher_2018-06-07_14-57-11.png (69.4 KiB) Viewed 23670 times
