Smooth line series
Amol
Smooth line series
Post by Amol » Tue Jul 31, 2018 2:19 pm
Hi Steema,
We are facing one problem that is when we draw a line series on chart the series is not looking smooth as shown in below figure:-
So kindly assist us to give the solution so we draw the line series smooth.
Thanks & regards
PlanoResearch
Re: Smooth line series
Post by Sandra » Wed Aug 08, 2018 12:53 pm
Hello amol,
The code below do smoothing for us, using SootingMode as AntiAlias and setting smoothed line series propierty to true:
   Steema.TeeChart.TChart tChart1;
            tChart1 = new  Steema.TeeChart.TChart();
            this.Controls.Add(tChart1);
			tChart1.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.AntiAlias;
            Steema.TeeChart.Styles.Line line1 = new Line(tChart1.Chart);
			line1.Smoothed = true;
			line1.FillSampleValues(10);
Could you confirm us if the code above fix the problem you're experiencing?
Thanks in advance
Amol
Post by Amol » Thu Aug 09, 2018 2:19 pm
Hi Steama,
Thanks for the reply.
We have applied the code sent by you but we have still facing the same issue regarding the line smoothing.
For this we are sending one snap as showing below figure:-
So kindly assist us.
Thanks & regards
PlanoResearch
Post by Sandra » Mon Aug 13, 2018 10:18 am
Hello Amol,
Could you send us a simple project where we can reproduce the problem you're experiencing? Also, could you tell us which TeeChartFor.Net version are you using?
Thanks in advance
